20 Most Recent
Epson 2580 Perfection Photo Scanner Questions & Answers
Document Recognition
Hi!
Here is an OCR software which you can download for free.
Please click on the link to access free OCR (scan to text) software.
Thanks.
I want drive for my
Here is an
official link to download the drivers you request for. Just select your op. system (Windows XP, windows vista, win 7 etc) and proceed to download the twain drivers.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply including your op. system before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Up until I attached my
You need to install the scanner's driver ...->
this is the direct link for Epson 2580 scanner driver (mac) -::>ftp://ftp.epson.com/drivers/epson11927.dmg ..
- Download the file.
- Double-click the downloaded file to create a disk image on your desktop.
- Open the disk image.
- Double-click the installer icon to begin the installation.
How do I install the latest scanner driver in the Mac OS X 10.6.x (Snow Leopard) system?::>click
HERE
Plz give me link from
You will try these sites for Drivers
download.com
freewarefiles.com
brothersoft.com
Epson perfection 2580 scanner will not start
The first thing to try: a new USB cable and a different port. (If you are using a hub, try directly connecting to the computer). What does the device manager say about the scanner? (In Windows, access from the Control Panel > Hardware. Exact directions depend on the OS version.)
Check the transport lock on the bottom of the scanner - do not put the scanner on its side when you check the lock.
Make sure the scanner was on and had already warmed up (stopped blinking) before you tried to start the scanner software (either by the buttons or from the scanner). You may want to reboot the computer (in case the computer thinks one program has locked access to the scanner).
I hope this helps.
(scanners require two-way communication with the computer and a bad cable will stop the scan even when the computer sees the scanner and the software installed without a problem.)
I have an epson 2580 it now produces somewhat
The only way you're going to know if it's the scanner or the driver for sure is to install it on say an XP machine and see what results you get. If it's still dark, it's the scanner, if not, it's the driver.
Don't have software to install
I cant find any software and the new IE is now .eml and seems that it will not ... I don't have an account here, but again, if this works, I will be back. ...
tredosoft.com
Cleaning the glass
USUALLY you remove screws from the bottom of the unit and lift off the top. Not familiar with the unit.
