20 Most Recent HP LaserJet 3055 All-In-One Printer Questions & Answers
2answers
How do you create a link for a document?
Create a customized hyperlink to a document, file, or Web page-See this web page for help. Good luck! http://bit.ly/RU5uMO
9/17/2023 7:38:04 AM • HP LaserJet 3055... • Answered on Sep 17, 2023
FET transister 4004
1/9/2023 8:06:20 PM • HP LaserJet 3055... • Answered on Jan 09, 2023
2answers
My hp laserjet printer 3055
This can be caused by a number of reasons however it is mostly caused by the toner cartridge missing a small spring on one end. Try replacing toner cartridge first.
1/9/2023 8:06:18 PM • HP LaserJet 3055... • Answered on Jan 09, 2023
7answers
My printer shut off.
Hardware failure: during the starting/boot process the processor loads the firmware, moves the printing heads and the rollers and the precision of their movement is checked. If something is not right the boot process is aborted and an error code is displayed on the small LCD screen.
If no code is displayed then the defect is in the printer's processor itself - if this is the case the printer is effectively dead: the only way to fix that is to replace the mainboard and that would cost more than a whole new printer.
1/9/2023 12:23:34 PM • HP LaserJet 3055... • Answered on Jan 09, 2023
HOW TO SET TO DEFAULT PRINTER
1/9/2023 12:03:56 PM • HP LaserJet 3055... • Answered on Jan 09, 2023
2answers
Cant find the HP LaserJet driver on Windows 8
Go to this link, pull down to get to the WIN 8 OS that you have, and download the driver. HP LaserJet 3055 All in One Printer Drivers
1/9/2023 11:50:43 AM • HP LaserJet 3055... • Answered on Jan 09, 2023
3answers
I cant install my hp
Download the latest drivers from hp.
here is the link to your hp printer for windows 7
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1140780&prodTypeId=18972&prodSeriesId=1161389&swLang=8&taskId=135&swEnvOID=4062
1/9/2023 11:39:29 AM • HP LaserJet 3055... • Answered on Jan 09, 2023
5answers
HP Laser Jet 3055- "No print cartridge" message
This could also happen due to the censors.
Try these steps.
1. Take all the papers out from input tray.
2. Open the cart door & take the cart out,and let the door be open.
3. Turn Off the printer.
4. Clean the metal contacts on the cart.
5. Reinsert the papers & the cart.
6. Turn the printer on.
This could resolve the issue.
All the Best!!!!!!
9/27/2022 7:17:46 PM • HP LaserJet 3055... • Answered on Sep 27, 2022
2answers
No cartridge error message
yes, if no cartridge into printer, device will appear error message, but if have cartridge into printer, printer still appear message, it most likely your cartridge problems
Regards
9/27/2022 10:19:50 AM • HP LaserJet 3055... • Answered on Sep 27, 2022
When I try to install
I think you are connecting it through Network cable. And it happens at time that its not being detected because of the Internet Security program you are running as the computer takes it as foreign address.
I would like to assist you further in it.
9/22/2022 7:21:06 AM • HP LaserJet 3055... • Answered on Sep 22, 2022
4answers
Error code is 2753
Error #2753 is not a real code number for the HP 3055!
Please Visit here to check any other error codes regarding this machine here;
http://h10061.www1.hp.com/ccsearch/search?pname=HP+LaserJet+3055+All-in-One+Printer&qry=error+code+2753&submit.x=0&submit.y=0&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=1140780&productBigSeriesOid=12012&spid=1140612&opname=HP+LaserJet+3055+All-in-One+Printer&pname_desc=HP+LaserJet+3055+All-in-One+Print%2FScan%2FCopy&ptype=commercial&stype=pn&contextual_lname=&spname=HP+LaserJet+3055+All-in-One+Printer&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&search=0
Good Luck!
Rich Lilja
9/21/2022 9:11:06 AM • HP LaserJet 3055... • Answered on Sep 21, 2022
3answers
What is scanner error 2 on hp laserjet 3055
Flatbed scanner is bad replace whole top half p/n q6502-60116 approx. $150 - $200
3/12/2022 7:59:27 PM • HP LaserJet 3055... • Answered on Mar 12, 2022
Password
admin
7/29/2021 11:52:35 AM • HP LaserJet 3055... • Answered on Jul 29, 2021
Document loaded showing 3055
Sensor flag would have got stuck, check adf paper presence sensor
7/25/2021 7:07:28 PM • HP LaserJet 3055... • Answered on Jul 25, 2021
Says memory is low
Do the following:
1. Make sure that the memory does not have any faxes in it waiting to be sent if so send them.
2. Make sure that the memory does not contain any received faxes still waiting to be printed if so print them.
3. Use the HP ToolboxFX Fax tab to perform fax tasks from the computer. The Fax tab contains links to the following main pages:
● Fax Tasks. Perform such tasks as sending a fax or clearing the fax memory.
Fax Data Properties. Manage the space used to store faxes on a computer. These settings apply only if you have chosen to send or receive faxes remotely from the computer.
Enhanced I/O
The enhanced I/O (EIO) feature allows all-in-one memory to be used for storing data received from the
host computer. When EIO is enabled, more data can be sent to the all-in-one in shorter amounts of time
so that the user can return to the software program more quickly. The
EIO feature has the followingoptions:
Auto. The all-in-one uses EIO memory allocation to increase the speed of data transfer from the host computer to the all-in-one, if necessary. The default setting is Auto.
Off. The minimum amount of all-in-one memory is used to store data that is sent from the host computer.
Page Protect. The formatter creates the entire page image in page-buffer memory before physically moving the media through the all-in-one. This process ensures that the entire page is printed.
7/22/2021 6:06:22 AM • HP LaserJet 3055... • Answered on Jul 22, 2021
17answers
Fatal error installing HP 3055 all in one
OK, here is my debugged/tested solution.
I know your error refers to a different installer MSI file (CIOUM32.msi) but the installation component in your log file (ipm12.A4B24390_80AD_4BAF_B8FD_C670FE0DB586) is identical to the one that was giving me trouble as well (i.e. points to the same service/file). So it is definitely worth a shot to try this solution out as it will only take a few minutes.
My Scenario:
OS: MS Windows XP SP3 [Version 5.1.2600]
Printer: HP LaserJet 3390 (AiO) (Firmware datecode: 20070331)
Printer Connection: Connected via Ethernet with a static IP address
HP Driver Version: v4.0 (hp_LJ3050-3052-3055-3390-3392_Full_Solution_AMWE.exe)
Ran into same error that everyone else is experiencing. (see below)
Now Launching=X:\hpzmsi01.exe -m dot4msi -l XXX -f X:\DIVins??.DAT
Error message received: The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2753.
X:\HPZBDI32.msi failed with return code 1603
MSIInstall() failed with 1603
Exit code=1603
After debugging HP's installation scripts for 2 days, here is the cause & solution I identified to this specific install error. Once I got passed this error, everything installed without error and all functionality was working properly (including scanning!).
BACKGROUND:
Microsoft Installer (MSI) error 1603 is simply a generic "A fatal error occurred during installation" -- see http://msdn.microsoft.com/en-us/library/aa368542(VS.85).aspx. This is basically MSI telling you that something very bad has happened during the installation. In order to get more details, you can turn on MSI debug logging by following this MS Knowledge Base article (http://support.microsoft.com/kb/223300).
The MSI error code 2753 is the code for "The File '<file name>' is not marked for installation.". This error can be triggered by many scenarios, but usually, it has to do with the actual installation script not properly checking for the existence/non-existence of an installation file and then not marking it for either installation/removal. I know this sounds confusing, and it is. If your curious about all the possible causes, just Google for "msi 2753 not marked for installation" and you'll see lots of results which you can peruse for your own enjoyment.
In order to identify what was causing these 2 errors, I enabled debugging for MSI via the aforementioned MS KB article
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
If all goes well, the install should now run without any issues.
Hope this helps since many people (including myself) have spent a lot of time (and HP Support chats) trying to find a workaround for this issue.
If you find this solution helped you out, please feel free to make a small donation to my PayPal ;)
7/22/2021 6:02:28 AM • HP LaserJet 3055... • Answered on Jul 22, 2021
3answers
49 error in hp laserjet 3055
The HP Printer Error 49 is a connection error code. They can be hard to troubleshoot sometimes, But these failures can be a just substitute error that gets clear with a reboot or more hard errors that require a hardware replacement. Getting worried? Call our technical expertise our check these steps to know How to fix HP Printer Error 49. When you try and print a document with an HP printer you may receive the HP Printer Error 49. This is usually caused by a communications failure between the printer and the PC, or related file errors. If HP Printer Error 49 is not resolved, this might mean there's waste within the printer's inside. Check this Blog for a full solution or Call customer services. Facing Hp printer error 49. This Hp printer error 49 happens due to the failure of the printer driver software or due to a virus or malware invasion. We give online help for Any problem with HP printers. Follow Mentioned Blog for Solution
3/25/2021 8:06:42 AM • HP LaserJet 3055... • Answered on Mar 25, 2021
8answers
HP Laserjet 3055 with "scanner error 6 - turn off and on" error AND MORE SPAM AT 1-800-532-4187
hp laserjet 3055 by scanner error 6
Solution: I found a very small piece of paper between the glass and the scanner housing. The lamp's seen that and sent the error message. Nobody find that little stucked paper and the "IT expert" sad: need to buy a new machine because he can't repair it. So, sometimes the solution is very easy just need some attention. :)
3/3/2021 5:44:16 PM • HP LaserJet 3055... • Answered on Mar 03, 2021
HP LaserJet 3055 All-In-One Printer Logo
761 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
when try install
  • Office Equipment & Supplies
