20 Most Recent HP LaserJet 3800dtn Printer Questions & Answers
2answers
I cant get it to print color.
Download the HP print and scan doctor from their support website You have checked the colour cartridge is not empty ?
10/10/2015 3:00:16 AM • HP LaserJet... • Answered on Oct 10, 2015
2answers
I have a 3800dtn. Replaced the blue cartridge and now I get error 54.17 and message says turn power off and back on. I did and I still get the error.
You need to clean any accumulated toner out of the area near the top of the cartridge cavity. This error indicates that the printer was unable to perform a color plane registration on the cyan cartridge. Any chance you left the pull tap in the cartridge?
9/23/2014 4:33:41 AM • HP LaserJet... • Answered on Sep 23, 2014
0answers
49 FF01
Be the first to answer 1/15/2014 5:08:18 PM • HP LaserJet... • Posted on Jan 15, 2014Be the first to answer
0answers
49.4B1A error
Be the first to answer 10/5/2012 8:36:16 PM • HP LaserJet... • Posted on Oct 05, 2012Be the first to answer
0answers
Hp 59.70 error
Be the first to answer 9/22/2011 11:05:35 AM • HP LaserJet... • Posted on Sep 22, 2011Be the first to answer
Front door will not close
On the 3000/3600/3800 there are two sliding guides, one on each side of the printer that tend to break. There is also an expired service bulletin for the locking arms that hold the cartidges in. most likely the sliding guides and possibly the surrounding plastics are broken. RC1-6643-020CN Right guide, RC1-6636-000CN Left guide, RC1-6638-000CN Left slide cam are the three most common parts outside of the cartidge locks Q5982-67925. The tear down to get to these parts is fairly intensive for a non-tech, and requires some attention to alignment during reassembly or you'll get issues with the color printouts.
4/28/2011 4:14:32 PM • HP LaserJet... • Answered on Apr 28, 2011
Why does it print with no color when the
I have worked/ serviced similar Laserjet Color Printer with same issue.
Actually, prints with faded colors or different colors are due the the dust/ toner dust accumulated on the optics (mirrors and lenses) inside the printer, which refect the laser beams to form prints. For instance, red color is formed by a mix of yellow and magenta toners. The color is replaced by yellow due the the partial or complete blocking of the image laser beam for
magenta as the mirrors which reflect laser beam get covered with dust and toner (which partially blocks the laser beams). Hence the image is not produced properly. This needs professional hands for servicing and cleaning of the optics inside the printer. Note that first magenta goes off, followed by yellow, then cyan and lastly black. This is due to the mirrors placement inside the printer. Magenta is the last one facing upwards at 45 degrees angle and gets most of the dust and goes off first.
Rest assure that the printer requires ONLY CLEANING OF THE MIRRORS, which are inside the printer. So, it is advised that you get the printer serviced by any printer repair/ service professional. (Please note that the mirrors, lenses and scanner assembly inside such printers is extremely complex and can get damaged very easily especially the mirrors).
Hope it would help. If you need any clarification, let me know
Good Luck!
CreativeTECH
3/3/2011 7:18:19 AM • HP LaserJet... • Answered on Mar 03, 2011
PAPER JAM IN CASSETTE 3 WHIT RECICLATER PAPER
just try to clear whit wet cloth or alcohol paper feeding roller or replace it whit new one.
12/14/2010 7:12:42 AM • HP LaserJet... • Answered on Dec 14, 2010
Hp 3800 always shows paper
check for pieces of paper inside of printer.
chek paper path sensors for lack of moving
Good luck!!!
12/14/2010 7:10:43 AM • HP LaserJet... • Answered on Dec 14, 2010
2answers
I'm getting error code 49.4C02 what are my
Solve my problem
4/16/2010 8:34:29 PM • HP LaserJet... • Answered on Apr 16, 2010
if that jam is permenant in that cassete , then replace the pickup rolls, or contact me at [email protected]
regards
3/18/2010 11:39:10 AM • HP LaserJet... • Answered on Mar 18, 2010
Paper jam in tray three, I pilled the paper out
Try to replace the pickup Assembly (Rolls, Separation pads), put your printer in clean enviroment
3/16/2010 6:47:09 AM • HP LaserJet... • Answered on Mar 16, 2010
tip
Where to find the manual (pdf) for HP Laserjet 3800dn printer
Sometimes , it is convenient to have a soft copy of your user manual. You may also require it as you lost your original printed manual. This tip will guide you to your digital manual and explain how to download it.
Printed manuals are normally available at a cost from the product manufacturer. Please see the link below to contact the manufacturer and find out how to replace your printed manual.
To download a soft copy of your manual , please Click Here to go to the retrevo page for your manual. This is a excellent site that maintains a manual and product database of thousands of products available free to download in PDF format.
Please note that you will need pdf viewer software to be able to view the downloaded manual. I can recommend Adobe reader which is available for free download at the following location :
CLICK HERE to go to Adobe Reader download site.
To download you manual from retrevo , follow the above mentioned link.You will be taken to the product page. The following images are used as an example.
When your on this page , you can select to see reviews , prices , specs , an overview of the product and of coarse , the manual. You can just hit the big red manual button to proceed.
Now simply type in the capcha code and hit the red “download now” button to begin your manual download.
To go to the manufacturers website , click on the link below:
Canon USA
Canon Global
HP
Epson
Lexmark
Samsung
Brother
Please rate this tip if you found it useful.
Kind Regards
StephanSA
49.4C02 service erreur
Try this
1. Turn the printer off and then on.
2. Try printing a job from a different
program. If the job prints, try printing a
different file from the original program.
If the message appears only with a
certain program or print job, contact
the software vendor for assistance.
3. If the message persists with different
programs and print jobs, disconnect all
of the printer cables that connect to
the network or the computer.
4. Turn the printer off.
5. Remove all memory DIMMs or thirdparty
DIMMs from the printer. (Do not
remove the firmware DIMM in the
lower slot J1).
6. Remove the printer EIO card.
7. Turn the printer on.
8. If the error does not persist, install
each DIMM and EIO device one at a
time. Turn the printer off and then on
again after installing each device.
9. Replace DIMMs and EIO devices as
necessary.
10. Reconnect all of the printer cables.
11. If the error persists, replace the
firmware DIMM.
12. Replace the formatter and calibrate
the printer.
1/1/2010 8:27:11 PM • HP LaserJet... • Answered on Jan 01, 2010
My ph laserjet color printer 4650dn is showing
There is a fix for this issue @ http://www.fixyourownprinter.com/forums/printer/30528
11/4/2009 1:14:00 PM • HP LaserJet... • Answered on Nov 04, 2009
I need to print both
Goto Start > Printers & Faxes Right-click your printer icon and select properties. Click 'Printing Preferences' button close to the bottom. In the new window you will see some drop-down list boxes for paper size, paper type etc. You will also see a list box captioned 'Print on both sides'. Select the correct value from this list and click 'Apply'. Close dialogs by clicking OK buttons.
Good luck with duplex printing!
8/13/2009 12:19:32 PM • HP LaserJet... • Answered on Aug 13, 2009
Horizantal black lines across the page each time I print.
You have a bad black toner cartridge.
1/17/2009 12:13:49 PM • HP LaserJet... • Answered on Jan 17, 2009
HP LaserJet 3800dtn Printer Logo
29 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
get print color
  • Office Equipment & Supplies
