20 Most Recent
HP LaserJet 5550 Printer Questions & Answers
Hp 5550 dtn 10.00.00 supply memory erro
the chip is faulty on the black cartridge, change the black and it'll work, alternately you can out it diagnostic made and run without the cartridges being monitored
Hp color Laserjet printer 5550 printing very slow
Please check your paper tray adjustments and verify that the paper type for the tray is set to any type or plain (assuming you are printing on plain paper). In general, if the machine has reason to believe that there is a custom size or special type of media, it prints at half speed.
RFU load error
I have a printer HP Color Laser Jet 5550' i cont print when i on the perinter ther 59 er--co is come on printer screen and the printer can not work .waht sould i do it cont rest too plase
Can you print on 200gsm in the hp5550
i think you may have difficulty printing on that paper, thickest recommended is actually 150gm.
i would suggest if this stock is well bendable, give it a try, if it is very stiff - do not even bother, there is very torturous path on this printer and 180deg turn on 40mm (1 3/4") radius is not exactly easiest, later models of this printer were equipped with doors which allow print on transparencies and more stiff (thick) papers, if yours is from 2007/2008 - one of the first models - it may not have this doors.
for further info go there:
http://h20566.www2.hp.com/portal/site/hpsc/public/psi/manualsResults?sp4ts.oid=409994&ac.admitted=1423745430236.876444892.199480143
choose and download general reference, as i do not know more about your system - download and read both...
hope this will help you - do not forget to vote...
200gsm what?
Usually there's a setting for thicker papers, which slows down the fuser, so that the card gets heated right the way through and the toner will adhere better.
