20 Most Recent
HP OfficeJet V40 All-In-One InkJet Printer Questions & Answers
Pdf prints half page
I have an HP 5520 and have had to download drivers several times after a HP update. Do not know why but it has solved my printing problems in the past. Roger
How do I reattach the encoder strip?
Should be a fixed mount on the left side of the carriage and a sprint mounted latch on the right. You will be able to tell if you have through the carriage properly if the strip runs straight through.
Why do i have a error message c00f0401
HP OfficeJet V40 All-In-One InkJet Printer Error c00f0401 ...
www.fixya.com > ... > HP OfficeJet V40 All-In-One InkJet Printer
HP OfficeJet V40 All-In-One InkJet Printer, error c00f0401 related issues. ... ...errorC00F0401 This error message can occur if the all-in-one has been stored ...
Hp officejet v40 won't recognize new cartridge
Your printer may need to be reset.
* Turn on your printer and re-install the old empty printer cartridges
* Wait for the printer to finish its cycle for recognizing the printer cartridge.
* Turn off your printer and unplug it from the power source.
* Clean your printer head and the electrical connections of the new printer cartridge. Be careful if you have already tried to install this prior since the ink may run.
* Plug back the printer into the power source and turn on the printer.
* After the printer has warmed up, do the normal process of installing your new printer cartridge.
If this doesn't work, it could be that the printer cartridge is faulty. Take the printer
cartridge, its box and the receipt to the office supplies store or
computer store where you purchased this and ask for a replacement,
explaining the problem.
I hope this helps.
Horizontal White Lines
My 1st thought would be clean heads also. If ink is tanks only not heads take ink out and try cleaning heads with liquid cleaner available @ Staples or similar stores. Another fix might be to use alignment utility for your printers software; however before you do any of this if ink is old or nearly empty replace ink.
VERY SLOW PRINTING
>Refilled cartridges? replace with new one..>Un install & install the drivers .>try with another file print..
