20 Most Recent
Kyocera Mita Toner 37085011 for DC-3060 & DC-4060 Copiers Questions & Answers
My copier mita dc 3060 showing error code c 210
Hello Manuel sorry for your machine to be in that stake but have you tried to check on that paper conveying motors because that error is for those lift motors try to go on your machine run this code
press status/job cancel
enter 1087*2 twice
enter 906 and then you will see execute
the you press start to see whether it will stablize
M559200308
It is not a colour copier and uses toner cartridge.
Error code j6301
Adjust the finisher to the upper limits to resolve. The height from the factory is too low. Paper curl from moist paper will cause this jam code 6301.
Code c 610
You have not mentioned the modelThis error code means that the dim is at fault or requires re-seating into the machine.
KM-2035 error call service c6000
Hello sir; Just follow my instruction, I will help you to get rid off the error code; With front door open press10871087 then enter 163 press "start" key, final press " stop/clear " key to get out reset procedure.
Error c7400
Developing unit connector insertion
problem
Absence of the developing unit is
detected.
Developing unit
connector inserted
incorrectly.
Reinsert the developing unit connector if
necessary.
Defective developing
unit connector.
Replace the developing unit.
C4000 km 5050
Polygon motor synchronization problem
The polygon motor does not reach the
stable speed within 20 s of the START
signal turning on.
Check the connection of connector YC3 on
the engine PWB and laser scanner unit, and
the continuity across the connector terminals.
Repair or replace if necessary.
Defective polygon
motor.
Replace the laser scanner unit.
Defective engine
PWB.
Replace the engine PWB and check for correct
operation.
