20 Most Recent Uniden GMR-325/2 2-Way Radio Walkie Talkie Dual Pack Questions & Answers
Check your batteries. Static can be a sign of a bad or low battery. Swap batteries between the units to see if the problem moves to another radio.
Also, check your antenna and antenna connection.
Best regards.
Uniden GMR-325/2... | Answered on Apr 12, 2015
http://www.uniden.com/pdf/GMR325-2om.pdf
Uniden GMR-325/2... | Answered on Mar 04, 2015
Google this. Instructions usually available on line. Or communicate directly with the manufacturer.
Uniden GMR-325/2... | Answered on Feb 15, 2015
You should be able to order a replacement on line.
Check to see if the batteries are good and correctly installed.
theres a little tab on the top of the clip you need to depress
Uniden GMR-325/2... | Answered on Feb 11, 2015
25 hours is in standby only, not with receiving or transmitting, both draw much more current off the batteries
Uniden GMR-325/2... | Answered on Sep 14, 2014
I am assuming that you are speaking of the charger. The Red LED shows that the charger is plugged into the wall. It does not show the charge status of the radio. These are very simple units, and it is not a "smart" charger.
Uniden GMR-325/2... | Answered on Aug 02, 2014
Press and hold the call button until the "L" goes away.
Uniden GMR-325/2... | Answered on Aug 01, 2014
TX means to "Transmit" or to broadcast from your walkie talkie.
This model has a "Monitor Mode" feature that allows you to listen for weak signals on the current channel at the press of a key.
1.) To turn ON monitor mode:
Press and hold the volume/monitor up or down key. The rx icon will blink.
2.) To turn OFF monitor mode:
Press the volume/monitor up or down key. The rx icon will stop blinking.
Uniden GMR-325/2... | Answered on Jul 16, 2014
You have to be on the saame channel as them.
Uniden GMR-325/2... | Answered on Apr 27, 2014
Press the latch and slide the clip up and off
Uniden GMR-325/2... | Answered on Aug 15, 2013
Uniden GMR-325/2 2-Way Radio Walkie Talkie Dual Pack Logo
50 questions posted
Top Uniden Radio Communications Experts
Jason
Robert McClure
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Uniden Radio Communications
Most Popular Question
unit charges fine but second press talk
  • Radio Communications
