20 Most Recent
HP PSC 1350v All-In-One InkJet Printer Questions & Answers
Aligning printer after new ink cartridge inserted
SOLUTION:
Start the cartridge alignment by performing a series of button presses from the front panel of the product.
HP PSC 1200 and 1300 series:
Turn on the HP PSC 1200 or 1300 series product.
Disconnect the USB cable from the all-in-one.
Press the sequence of front panel buttons below to start the print cartridge alignment process.
The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
Press and hold Cancel .
While holding Cancel , press On .
When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
Press Cancel again.
Press Copies .
Press Paper Type .
Press Color Start Copy .
The alignment page will begin printing.
If the alignment page does not print, repeat the button-press sequence in this step.
When the alignment page has printed, place the page face down on the scanner glass and press Scan .
The alignment is complete when the On light stops blinking.
Reconnect the USB cable.
CAUSE:
This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
How to clean the print nozzles
HP has a great white paper on the subject and they say it better and faster than I can write it. Click on the link that follows:
CLICK HEREI also found a short tutorial video that may be of assistance.
How to get hp 1350 out of idle mode?
The best way to get the printer back from sleep mode is to disconnected the power cord from back of the printer ( while the printer has power ) and wait for 30 seconds and connected it back.Regards,Suhail
HP psc1350 won't scan to macbook pro
Did you try to scan, using the HP solution centre? this will sometimes help. It is standard software from the User-CD, that comes with the HP printer
When i turn on my
Hello Mindy,
The problem you are facing may be due to cartridge miss alignment.
Please visit the help link provided below :
https://h10025.www1.hp.com/ewfrf/wc/document?docname=c00033431&lc=en&dlc=en&cc=us&product=306895#N247
Wont install to windows vista with download.cant
not 100% sure what you're asking here. if you want vista driver for your printer, it's here http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=323007&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=306884
if you're looking to download windows vista it is only availalbe from microsoft http://windows.microsoft.com/en-US/windows-vista/products/get
I'm just trying to find
The solution should be posted with your original problem, all responding posts get listed lower on the page....
