20 Most Recent
HP DeskJet 950c / ScanJet 5370C InkJet Printer Questions & Answers
Had a paper jam, now
See if the alignments for the paper are properly place to guide the paper,nothing loose.Thank you.
HP 950C - no red!
I use a clear silicone tube to carefully prime the carts by sucking a
dab of ink out of the tiny print holes before installation. I am
careful to have a tight seal at the holes to prevent getting too much
ink and possibly getting it in my mouth.
HP Deskjet 950C - trouble loading ink cartridges
1st thing would be to remove the cartridge & check for any damage to the copper contacts as these are what tell the printer that a new cart has been installed. Next make sure you removed the tape covering the nozzles (I've done this before & boy do you feel silly).
If this all looks OK then pull the power out while the cart is still not fitted (this will fully reset the printer).
Once it comes back up, try fitting the cart again also checking that the contacts in the cartridge holder are not damaged/dirty.
This should sort the problem
Cheers
Shaun
Hp scanjet 5370c
To print the document in color, follow the below steps..
Click Start , Settings , and Printers.
Right-click your printer and click Properties.
In Features , make sure Print in Grayscale is not checked.
Click OK.
Close the Printers window and print the document.
Thank you.......
How to reset HP ink ADVANTAGE 3515 Printer
Hello. First of all I would like to wish everyone a Happy New Year!
I recently bought a HP Deskjet Ink Advantage 3515 printer. The printer works fine (prints, scans and copies). There is only one problem with it. It returns me an error when I'm shutting it off. This happens very often but not always, it is kinda annoying. The error is displayed as: ERROR CODE 0X02B7C2ED SM_MODULE C (the error is also shown on the image). I tried to Google the problem but without effects. I don't know what could be the problem. Can someone help me please, because I have no idea what could be the issue. Thanks for any replays.
How do I fix an Hp deskjet 4615 not printing black?
If you are using a Windows PC, search for devices and printers. Once you find the printer, right click on it, go into printing preferences and you should find a tab in there that will all you to disable color.
If you want to be able to print in both and black will not print, make sure your black ink cartridge is not empty or that it is properly installed.
My printer cutting text from the right side when printing .HP deskjet 2050 J510
Check the paper size settings to match the loaded paper. This would happen (for example) if you have loaded A4 paper but your driver is set to print on letter format. Letter is wider than A4 by 6mm and while the printer is trying to print near to the right side, assuming the paper is wider, part of the ink goes on the paper support. Other reason may be the paper size in the document is set to be larger than the loaded paper format and driver prints only what can be fit on the loaded paper.
I have error 0xc19a0023 in my printer hp deskjet 3520.I replaced new cartridge but it isn't correct.What should I do?
1) Open the printer cover and wait till the carriage moves towards the middle.
2) Force press the printer's Power button to turn it off. Remove the power cord from the back of the printer.
3) Remove the print cartridges and place it on a small sheet with the nozzle plate facing upward.
4) Slightly wet a cotton swab with distilled water. Clean the face and edges of the face cartridges with the swab.
5) Wipe the underside of the print cartridge cradle walls using a swab. Reinsert the print cartridges.
6) Close the printer cover. Connect the power cord at the backside of the printer.
How do I scan multiple pages to one file using a deskjet 2512 printer/scanner
On the control panel, select scan to computer and choose PDF.
If you are using the sheet feeder, it will scan all pages and create one file with them all.
OR
If you're using a scanner glass, i.e. one page at a time, when the first page finishes scanning, you will get a message asking if you have another - answer YES and follow the instructions (basically that means place next page on scanner glass and hit OK/Continue). Rinse and repeat until you've scanned all pages then answer NO.
You should find a PDF file in your HP Scan Folder usually named "scan.pdf" unless you've changed the settings. (If there is/are already scanned files in that folder, they will have consecutive numbers, e.g. "scan001.pdf" "scan002.pdf" etc
10/11/2018 10:24:24 AM •
HP DeskJet...
Answered
on Oct 11, 2018
