20 Most Recent
Kyocera Mita KM2540 Black Toner Cartridge Genuine Questions & Answers
Error code j6301
Adjust the finisher to the upper limits to resolve. The height from the factory is too low. Paper curl from moist paper will cause this jam code 6301.
Code c 610
You have not mentioned the modelThis error code means that the dim is at fault or requires re-seating into the machine.
KM-2035 error call service c6000
Hello sir; Just follow my instruction, I will help you to get rid off the error code; With front door open press10871087 then enter 163 press "start" key, final press " stop/clear " key to get out reset procedure.
Error c7400
Developing unit connector insertion
problem
Absence of the developing unit is
detected.
Developing unit
connector inserted
incorrectly.
Reinsert the developing unit connector if
necessary.
Defective developing
unit connector.
Replace the developing unit.
C4000 km 5050
Polygon motor synchronization problem
The polygon motor does not reach the
stable speed within 20 s of the START
signal turning on.
Check the connection of connector YC3 on
the engine PWB and laser scanner unit, and
the continuity across the connector terminals.
Repair or replace if necessary.
Defective polygon
motor.
Replace the laser scanner unit.
Defective engine
PWB.
Replace the engine PWB and check for correct
operation.
C3200 error
Exposure lamp problem
When input value at the time of exposure
lamp illumination does not exceed the
threshold value between 5 s.
Check the connection of connector YC5 on
the ISM PWB and the connector on the
inverter PWB, and the continuity across the
connector terminals. Repair or replace if
necessary.
Defective exposure
lamp or inverter
PWB.
Replace the exposure lamp or inverter
PWB.
Incorrect shading
position.
Adjust the position of the contact glass
(shading plate). If the problem still occurs,
replace the home position switch.
Defective PWB. Replace the ISM PWB, ISC PWB or CCD
PWB and check for correct operation.
Error code c-6000
fuser related problem press 1087*2 then 163 and start click start en execute
Error code c-6
Your machine have a fuser Unit problem. Usually on the older models the fuse needs to be replaced or reset.
