20 Most Recent
Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin Oil Radiato Heater Questions & Answers
Need users manual for a Kaz oil heater
I dug up my user's manual just the another night to address a problem I had. If you contact me and still need a copy of it I will scan it and email it to you. It is a good reference on how to run the heater but doesn't say much about troubleshooting problems. To learn about that you have to email Honeywell, which I did, and haven't received a response yet.
I need an owners manual
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can't find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Help
I have searched it myself and can't find it online, May I suggest contacting the manufacturer, Honeywell/Kaz direct at 800-332-1110.
Instruction Manual for HZ-705
HZ 709
This model# is the closet we'll are gonna get unless I can find my manual and get it scanned.
Scroll down to page 4.These instructions will give you a basic idea how this heater works.
Good Luck :-)
http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Which of the outside wires is the hot
one of the conductors has a rib impressed into the insulation - this is the "identified" conductor and goes on the nickel colored screw of the replacement plug. the other is the "black" or hot and goes to the brass colored screw.
With no colour coded insulation, knowing which wire is hot
Take your old cord out. If you notice there is one side that is a little bigger than the other. Take a meter and measure the continuity from the larger side to the wire end and thats how you can tell which is which. Do the same on your new cord and that will tell you which one to put where. Like this..... ------>l l<----
o
Defective plug Honeywell HZ 680C
just change the plug - get it at a hardware store. if your cord is flat, the center conductor is earth ground, green screw. the ribbed conductor is the neutral (white) and the ribbed conductor is the hot (black)
