20 Most Recent Tektronix TDS1012 Questions & Answers
good for you
Tektronix Office... | Answered on Feb 01, 2015
Hello Sancorp,
In order to provide you a better solution I request you to provide me the opearating system you are using and also the make of the computer.
Thank you.
Tektronix Office... | Answered on Oct 26, 2008
This is from the 560 manual hope the codes are the same. The 560 manual states : Accumulator belt cleaning blade movement error.
1. inspect the cleaning blade{located on the imaging unit,along the bottom of the green OPC belt. Is it flipped up? If you cannot flip it down, replace the imaging unit.
2. Inspect the wiring harness leading from the cleaning board to CN18 of the engine control board.
3. Replace the cleaning board.
4. Replace the engine control board.
If the above info does not match your model call :
(800) 833-9200 Press 3
(503) 627-2400
Tektronix Office... | Answered on Aug 21, 2008
Given a journal is a record of events as they happen in chronological order, usually a personal record, your journal can have an introduction, a prologue or an epilogue or whatever you want.
If you want it to be a comprehensive record you can include "asides" or explanatory notes that make things clear to subsequent readers. These can be in the form of footnotes on each page, at the end of each time period or in the form of an appendix at the end of each journal.
Office Equipment... | Answered on Dec 09, 2019
i know what the problem may be phone 07764303923
advise is free
https://www.fix.com/parts/appliance/
  1. Unplug the shredder for safety. ...
  2. Remove the top "shredding" portion if possible. ...
  3. Use a pair of tweezers to pull pieces of paper from the blades. ...
  4. Cut curled-up pieces of paper with a knife, then tug them out.
Office Equipment... | Answered on Dec 08, 2019
make & model of the device?
Tektronix TDS1012 Logo
3 questions posted
Top Tektronix Office Equipment & Supplies Experts
Vincent G
Vincent G
ANTISPAMMER
Vuk B
Are you a Tektronix Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Tektronix Office Equipment & Supplies
Most Popular Question
tektronix tds 1012 manual
  • Office Equipment & Supplies
