20 Most Recent
Konica Minolta Minolta Bizhub C253 Copier Questions & Answers
Helo,
this code C2151 is showing in my Konica Minolta bizhub c253. please how can I cancel the code. kindly help please.
When you open the right side door and look down at it you see a sponge looking roller. That is called Second transfer roller. The paper will go between that roller and transfer belt the shinney belt inside the machine it aligns with. During operation the roller should retract. There is a senor and motor that work together to execute the procedure. You will have to remove the assy. to get to the motor and sensor if its not them its the main board serious buckets and I doubt you can get one.
What does code c-225D mean on a bizhub c253
remove all of the image units, shake each one so as to have the developer in each unit be spread out along the entire unit not at one end, after doing that to each one install them properly. open close front door to clear code if it come back if these image units are third party get real Konicaminolta units and get a tech out Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
C-2253 erroe code
DID Some one recently replace a color image unit? Was that image unit stored standing up? and placed directly into the machine.? Might have all the developer sitting at one end and motor can not turn. Pull out all the image units, shake each one along the axis of the unit to spread the developer over the entire length of each image unit, then re-install, open close front door to reset code, if the code comes back you might have a burn out color image motor, or on of the color image unit needs to be replaced replace all three, worse case the board that controls the motor was damaged. Store all Image units and toner length wise Btw, I’m available to help over the phone in case u need at
Konica minolta bizhub c253
what is the question?
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Konica C253 no network settings
If you have a Fiery rip fitted to the machine then the standard network settings in the admin menu will not be there.
you need to click on the (i) icon on the front screen of the copier and this will open the fiery menu.
from there you can select print pages>config page and find all the details you need.
hope this helps
Lost yellow and magenta in test print
Enter in the service mode and select tes mode select gradation test pattern and make a test for black,cyan,magenta and yellow.If the gradation is not OK you have change the bad imaging unit,or change the developer and drum in the bad image unit + the chip.
