20 Most Recent
Dell 1100 Laser Printer Questions & Answers
Prints multiple copies of job and will not shut
Unplug the power cord from the printer. Hold down the red "X" button. Plug the power cord back in while holding down this button. Release the button. Should see flashing red and green lights. Unplug the power cord again. Replug. Should be reset.
Does not go. Does
You may want to open it up and clean it out, (dust etc) it may having a thermo error thus shutting down to prevent any melting/overheating.
Can not print envelop with Dell 1110 Laser
- Turn the printer off.
- Wait 10 seconds.
- Turn the printer on.
- Determine if the issue still occurs.
restart the computer:
- Click Start and then Shut Down.
- Click Restart.
The computer restarts.
My Dell 1100 printer is
With your printer, it's not possible to simply unlock and pull out the fuser unit, but to clear the paper jam inside or near the fuser unit, you have to access from the front.
Open the front access door, pull out the toner cartridge and the drum, then you'll be able to see-through the passage upto the Fuser unit. From there you can pull out any obstructions or broken paper stuck beside or inside the compartment. To remove your fuser, you'll need to remove the screws (there should be two screws,). But this is not included in the troubleshooting measures, you can still remove the jammed paper from the front access door. If you don't know how to disassemble the machine, I wouldn't recommend you do it yourself, rather call a friend or other guy who has a little disassembling laser printer and help you fix it. Please note that fuser unit is very hot and you can only access it after the printer is kept off for at least 30 minutes, if done without proper precaution, you may damage the fuser unit (I hope you understand the contraction and expansion of an object when heated and cooled).
Removing fuser in a Dell printer (all almost dell printers) requires at least 4 screws to be removed and it's also in two steps, one before you reach the unit i.e. removing the cover and next, after removing the cover. It's fitted inside the compartment which is not accessible like Hp or other laser printers.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
I am trying to insert
The cartridge has a handle that folds down. You can reach in and remove the old one by pulling it straight out while firmly grasping the handle. Then simply slide the old one back in to get a feel for it. The new cartridge should look very similar to the old one and goes in exactly the same way as the old one.
Paper feeder stops after in about 2 inches
Have you tried cleaning the feed rollers with rubbing alcohol or soapy water? Just make sure to dry the rollers before trying to use the printer again. If this doesn't remedy the problem, check the paper feed path for obstructions (previous misfeeds or jams). Hope this helps.
