20 Most Recent Panasonic KX-TG5632 Phone Questions & Answers
Can i retrieve a message that was erased
I'm sorry to be the bearer of bad news but it is not possible to retrieve your messages.
Jamiell
2/25/2021 9:20:11 AM • Panasonic... • Answered on Feb 25, 2021
2answers
Panasonic cordless phone,
press menu,scroll down to ringer settings,hit select,scroll to ringer volume and hit select then press up the round button in the middle until you hear it make a "ring" sound. adjust your preferred volume and hit save.
12/19/2019 4:48:17 PM • Panasonic... • Answered on Dec 19, 2019
3answers
Panasonic KX-TGA101S base not charging.
Here are a couple things you can try.
Clean the charging contacts, this can be done two ways. The manufacture's recommend using a pencil eraser. I recomend using a q-tip and some rubbing alchol. Just rub the alchol soaked q-tip on all the metal contacts on the bases and the bottom of the handset.
Gooo luck.
Hope this helps
4/8/2019 12:40:44 PM • Panasonic... • Answered on Apr 08, 2019
Panasonic Phones are on mute and will not work
The following is generic for most cordless phones:
Did you check to make sure that the phone is not in the intercom mode? If this phone has a base station speaker phone, make sure it is not on mute. Some of these phones have a fax connection. Make sure your phone line is not accidently pluged in to the fax section. Also if the phone has a fax monitoring feature check the the setup menu that the fax is not enabled. If the phone has an answering machine mode, make sure that this feature is turned off.
In the worse case:
There may be a defect in the X-Mit section of the phone. I would suspect the fault to be in the base.
Jerry G.
6/6/2018 9:30:11 PM • Panasonic... • Answered on Jun 06, 2018
2answers
Messages are full, but don't
No. It stores to a hard drive. Save the phone and buy a new answering machine. Or buy a new phone w/ answering machine. I’m happy to assist further over the phone at https://www.6ya.com/expert/steven_958e67a4edcc47d5
11/10/2017 1:40:22 PM • Panasonic... • Answered on Nov 10, 2017
0answers
Only on one of my two phones am i having a problem, I pick up the phone call someone after our talk is over I hit the off button & nothing happens it well not make the off dial tone. So I hang the
Hello, friend! I also meet this error about my cell phone, I get many help from this forum, and also bought many DIY repair tools from china supplier , and vipprogrammer help me fix this error. maybe you can try it.or contact ther WhatsApp:+ 8615986801289 website: http://www.vipprogrammer.com. They've solved my cell phone problem and I hope it will help you with your mobile phone trouble.
10/7/2017 3:06:07 AM • Panasonic... • Answered on Oct 07, 2017
3answers
No link to basse
one of the phones has a no like to base error. I have put it on the base. Taken the battery out and replaced. What's up?
5/2/2015 2:04:08 PM • Panasonic... • Answered on May 02, 2015
When I receive a call
Sounds like you have voicemail from your service provider and it might need to be activated before allowing messages to be recorded . If you do have voicemail on your number and it is set to answer after 3 rings and your answer machine is set to answer after 4 rings, then the caller will never get to your answer machine. Voicemail is often automatically added by service providers, especially if you have recently changed service providers or your service provider has upgraded their telephone switch equipment. I suggest you call your service provider's customer service number and ask them if your telephone line has voicemail and if you don't want to use it, have them disable it. If the service provider says you do not have voicemail then report the problem as a trouble on your telephone line.
8/26/2014 7:04:57 PM • Panasonic... • Answered on Aug 26, 2014
Why can't I call out
It is possible the handset unit is not talking to the base station. Try to receive an external call (made from other phone or cell) on the hands free and check if that works. If not then register the handsets to the base station. It is also possible the phone has not been configured for the correct dialing protocol. Refer user manual at this site. http://service.us.panasonic.com/OPERMANPDF/KXTG5631S.pdf
8/6/2014 7:19:02 AM • Panasonic... • Answered on Aug 06, 2014
manual
Why my idect phone wil not switch on or charge
Hey make sure the battery is inserted correctly and the plug is plugged in for the charger! If you need further help, I’m available over the phone at https://www.6ya.com/expert/anik_29134a102eb94344
7/13/2014 5:01:22 AM • Panasonic... • Answered on Jul 13, 2014
0answers
2answers
Ringer
Hold the Low volume key on the base unit for sometime. A beep will sound that means the ringer of the base unit is off.
4/25/2014 6:53:34 PM • Panasonic... • Answered on Apr 25, 2014
419 questions posted
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Lands Phones
Most Popular Question
need extension power cord tg5632
  • Lands Phones
