20 Most Recent Motorola Mobility H700 Wireless Headset Questions & Answers
It can happen when phones update their software. It also can occur when the earset battery gets too old to hold the full charge.
Motorola... | Answered on Dec 12, 2017
Go to bluetooth and see what is listed click on it and remove device. Start over.
Motorola... | Answered on May 03, 2017
Here is a list of compatible bluetooth headsets taken from the Blackberry web site.
  • Flamingo™ Bluetooth Headset *
  • Jabra® BT250v
  • Jabra JX10
  • Jabra BT125
  • Logitech® Mobile Pro™ Headset
  • Motorola® Bluetooth Headset H500 **
  • Motorola Bluetooth Headset HS820
  • Motorola Bluetooth Headset HS850
  • nXZEN™ 5000
  • Plantronics M3000 Bluetooth Headset
  • Plantronics Discovery™ 640 Bluetooth Headset
  • Plantronics Explorer™ 320 Bluetooth Headset
  • Plantronics Voyager™ 510 Bluetooth Headset
  • scala-500™ ***
  • Sony® Ericsson® Akono™ Bluetooth Headset HBH-602
  • It may be a compatibility issue with the H700. You may want to make sure the volume is turned up fully on the headset as well.
    Good Luck
    Motorola... | Answered on Nov 26, 2016
    Hi Aggie,
    So sorry to hear that, let me tell you that we don't longer manufacture those devices but if you are able to find a battery in a third party site like Amazon or best buy.
    Hope you can solve the issue.
    Regards,
    Marvin
    Motorola Support.
    Motorola... | Answered on Oct 06, 2016
    Is the headset paired and connected to your phone? Is bluetooth turned on in your phone? Look for the bluetooth icon on top of your phone's screen. Let me know what model phone you have and I can help you troubleshoot.
    Motorola... | Answered on Jan 28, 2016
    try another pass key as the system may not accept that combination
    Motorola... | Answered on Nov 08, 2015
    Kingram and Mike-
    On nearly all our headsets it is 0000.
    Mark
    Motorola Support
    Motorola... | Answered on Apr 24, 2015
    Chris
    Charge with boom closed. If previously paired with your phone and bluetooth is enabled. It should auto connect when boom is opened. Pairing on this model is tricky for some.
    Mark
    Motorola Support
    Motorola... | Answered on Mar 05, 2015
    The batteries in our headsets are not intended to be swapped.
    Mark
    Motorola Support
    Motorola... | Answered on Feb 23, 2015
    Enable Bluetooth on your Defy. Then follow these instructions H700 Different Paring Instructions then search for H700 on your Defy.
    Mark
    Motorola Support
    Motorola... | Answered on Feb 10, 2015
    Mark-
    I remember this headset being difficult for people to get in pairing mode. You can find instructions here. H700 Different Paring Instructions
    Mark
    Motorola Support
    Motorola... | Answered on Jan 13, 2015
    Have you tried both volume buttons simultaneously while in call? Otherwise your phone probably has a one button option.
    Mark
    Motorola Support
    Motorola... | Answered on Jan 12, 2015
    If tv is bluetooth capable, look under menus and pair with H700.
    Phones if initially paired will simply need to have bluetooth 'active' (as by default it is usually off). - If not pair - you will need to go through menus under 'settings' to pair with the H700 (also at this point indicate that the H700 is 'trusted device').
    Motorola... | Answered on Nov 28, 2014
    Lisa-
    If your headset is a Motorola headset we recommend you CONTACT US
    Mark
    Motorola Support
    Motorola... | Answered on Aug 27, 2014
    Motorola Mobility H700 Wireless Headset Logo
    756 questions posted
    Top Motorola Mobility Radio Communications Experts
    Lawrence Oravetz
    Dennis Webber
    Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
    View Most Popular
    • Motorola Mobility Radio Communications
    Most Popular Question
    h700 bluetooth hear caller but 39 t
    • Radio Communications
