20 Most Recent
Motorola Mobility Logitech Mobile Bluetooth Over the Ear Headset for RAZR V3c Verizon Cell Phone (980228) Headset Questions & Answers
Cell phone losing time
It sounds like you are in a poor coverage area of under a metal roof. The phone(s) will scan and scan, losing battery charge quickly because they are not designed to scan for long. Calls going to VM and unable to call out simply confirm this to me. New phone will never fix a coverage issue. Buy a high end cellular booster, install it correctly and your phone will work. I cannot emphasize installation enough, I never had a unit return in 18 years if we installed it and had a 70% return by lazy customers. We stopped selling them without installation. Good luck. Start with Wilson and go higher in price if you can.
6/29/2017 5:56:26 PM •
Motorola...
Answered
on Jun 29, 2017
Music downloads
What is your phone ?
If it has blue tooth you can pair to a bluetooth enabled Laptop and transfer files..
Else , try to get a data cable and software depending on you phone and you can then transfer. Data cable specific to phone is fastest
11/12/2009 12:31:47 AM •
Motorola...
Answered
on Nov 12, 2009
Still froze
Does the light blink blue other wise and show red when charging ?
Make sure ear set is fully charged overnite?
Turn off and turn on.
Only then when turning on, DONT REMOVE YOUR FINGERS AND KEEP PRESSED for about 10-30 Seconds,, Watch for SOLID BLUE... Remove and proceed to pair..
If it still does not work, I would suggest that you keep trying .. Since I assume that the phone is charging well and then discharging over a time..
6/17/2009 7:01:31 AM •
Motorola...
Answered
on Jun 17, 2009
Motorola v3 mobile phoe
YOu can try to send MMS of these pictures to an email address such as yahoo or gmail and that way it will get to your computer.
6/17/2009 6:59:21 AM •
Motorola...
Answered
on Jun 17, 2009
Icom IC706mk2g Transceiver does not transmit in SSB (Single Side Band) (USB & LSB)
First, make sure that the microphone is properly connected to the transceiver. Check all the connections and ensure that there are no loose cables.
Next, check the settings on the transceiver to make sure that it is set to SSB mode. Sometimes, the mode settings can get changed accidentally, so it's important to double-check.
If the issue still persists, try resetting the transceiver to its factory settings. This can sometimes resolve any software glitches that may be causing the problem.
If none of these steps work, it's possible that there may be a hardware issue with the transceiver. In that case, it's best to contact a professional technician for further assistance.
3/28/2024 10:24:30 AM •
Radio...
Answered
11 hours ago
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
