20 Most Recent
HP Compaq d530 SFF PC Desktop Questions & Answers
HP compaq d530s SFF pci slot1 not worknig
Hi , with the computer powered off and ac power plug removed, press down on power button to discharge any residual energy noting any mainboard mounted LED lights have stopped glowing, then try reseating the " horizontal mounting bracket" ( remove the attached expansion card device ) restart computer , then shut down again , install the expansion card device and restart - hopefully now the pci bus will connect and the card detected and reinstalled by Windows
Hp compaq pd1068p driver download
so , you meant ? "where can I" ? as in a real question?
Abdellatif Ziati wants answers to this question , hyJacking 2013 posts to the wrong forum D530??
NO OS stated, and drivers match, OS, windows what.
and what fails, what feature fails,,
the PC D530 is obsolete and HP has no support now for it.
so google all day long and find it, and get the PC infected.
ive no idea what pd1069p is.... nor does HP searches find it.
the D530 is 14 year old now. an old Pentium 4 box.
some came with windows 2000, (17 year old OS)
here is the old data sheet on this Relic PC.
http://www.hp.com/ecomcat/hpcatalog/specs/emeapsg/99/D530SERIES.pdf
we take these to the dumps, and give it the last rights. RIP
920-fan command 2 pin connector from power supply
Well thats not good, however if you can identify the Positive, usually RED, and Negative, usually BLACK. on the Fan, You can actually carefully insert the bared wire into a spare drive power connector, fans are all 12 V. You can use the YELLOW.. +12V & the alongside BLACK - 0V. This will power your fan. BE CAREFUL doing this. Once inserted use a piece of tape to secure the wires and fold them back against the Plug and secure. You may be able to buy a converter that plugs into that power connector & the fan?
Bios update for win 8
refer to HP support website, type your model. available bios updates are ready for download in there.
