20 Most Recent
HP Compaq Business d530 Ultra-Slim PC Desktop Questions & Answers
1801 microcode error dc5100
Muhammad Ilyas wants answers to this question
NO PC stated, (yours)
NO OS stated (YOURS is this VISTA the pig that has no built in service recovery mode?)
why not start your own post, and not Hyjack others.?
lazy?
ever google , or on this?
if you had you'd have seen others had this, error.
you are never the first to get an error. nor last.
when did the pc last not give errors.?
I just bought it for $1 in garage sale, what?
D530 or DC5100
which is it, nobody can tell, lacking OP crazy, statement.
why hyjack posts that are no good with conflicted facts.
here ill type in google for you
then see 1st hit. next
https://h30434.www3.hp.com/t5/Desktops-Archive-Read-Only/how-can-I-fix-quot-1801-microcode-update-error-quot-I-have-a/td-p/1257693
there you go , for all those folks afraid of googling and reading
there you go.(based on bad input, so my answer can be wrong)
8/3/2018 2:17:58 PM •
HP Compaq...
Answered
on Aug 03, 2018
HP D32s manual
All HP manuals are available on the HP support site.
12/18/2014 12:50:00 PM •
HP Compaq...
Answered
on Dec 18, 2014
Five beep in Hp compaq
1 short beep and 1 long beep
Memory problem
2 short beeps and 1 long beep (repeats 5 times)
Unable to initialize video or video card required but not installed
3 short beeps and 1 long beep
CPU configuration error or CPU type is not compatible
The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS :
Beeps
Description
1 short beep
Legacy floppy drive or CD/DVD drive not detected
2 short beeps
Floppy diskette or compact disc not detected
3 short beeps
Unable to start flashing (such as when missing a utility or BIOS image)
4 short beeps
Flashing failed (checksum error, corrupted image, etc.)
5 short beeps
BIOS recovery successful
8/29/2014 9:25:39 PM •
HP Compaq...
Answered
on Aug 29, 2014
Computer beeping and flashing red light
This means that the rams on the main board is gone,1.) unplug the system and open the case.2.) locate the memory Module (rams) its a small long circuit board clipped into a slot and held in place by pins on eighter side3.) purchase the exact sme module from a local store4.) put in new module.ps you can try cleaning it with tissue paper when you remove it as well before buying a new one.
12/29/2012 12:33:08 AM •
HP Compaq...
Answered
on Dec 29, 2012
How can I reprogram my HPcompaq tower for internet service?
Check Device Manager. If the drive is missing download, extract and install via a USB pen drive.Mine uses the Broadcom drivers.http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=316715&prodTypeId=12454&prodSeriesId=316713&swLang=13&taskId=135&swEnvOID=1093#11395
11/15/2012 4:49:59 PM •
HP Compaq...
Answered
on Nov 15, 2012
HP Compaq d530
it all depends on the number of flashes , pause, repeat.
Since the problem did not indicate any beeps her is the following info
Power LED blinks RED 2 times, one every second, followed by a
2-second pause. = Processor Thermal Protection Activated
3 blinks 1 second apart = Processor not installed (not an indicator for a bad processor).
4 blinks 1 second apart .= Power Failure (power supply is overloaded)
Other possibilities are:
5 blinks 1 second apart No memory
6 blinks 1 second apart No graphics
7 blinks 1 second apart System board failure (detected prior to video)
8 blinks 1 second apart Invalid ROM
7/25/2012 6:00:45 AM •
HP Compaq...
Answered
on Jul 25, 2012
Have my hp desktop whose red light at fornt just
The color of the lights are different on a CASE by case basis. I wouldn't get overly fixated on the lights. If your getting just some lights on and maybe some of the fans then I would start by replacing the power supply. Easy to do just google or youtube "install PSU" and you will have lots of videos on it. All the connectors are keyed (they only fiit one way) and only on the right devices. Comment back if you need more information or help.
11/2/2011 12:00:42 AM •
HP Compaq...
Answered
on Nov 02, 2011
As soon as i connect
1. your power supply has a bad connector, cord or is about to fail.
2. replace the power supply.
9/12/2011 4:09:11 PM •
HP Compaq...
Answered
on Sep 12, 2011
Buena pero tengo un error
Buenas tardes, pues pueden entrar a este link para que puedan arreglar ese problema. Lo unico es que el link es en ingles.. Si pueden conseguir a alguien que los ayuden pues aqui esta todo lo que necesitan saber.. espero que esto le sirva de ayuda..
http://www.wallpaperama.com/forums/how-to-disable-press-f1-to-continue-when-booting-make-change-bios-boot-t482.html
Coloque este link en su browser...
Si encuentra que esto es informaci?n fue ?til a usted, por favor me valora y deja un comentario como esto me favorecer? a hacer el trabajo m?s libre para usted y para otros. Y permiti? por favor que s? si hay otra cosa con que podr?a ayudar usted. ¡Gracias por utilizar FIXYA! Los saludos, Junior
9/11/2011 9:49:49 PM •
HP Compaq...
Answered
on Sep 11, 2011
My computer keeps beeping and
Possible that PC is hanging up as there is fault on the OS ( operating system) or a virus in the OS. Also it is possible that the back up( CMOS) has low voltage or the memory card is a suspect. In this case you need to check the voltage and also try and swap a memory card. If not the OS is a suspect.
If the PC boots up then open the internet options in the browser and clean all the cookies, temporary internet files, defragment the drives and RESTORE the PC to an earlier set date.
You can use a registry cleaner like Advanced system care. Download from the site and check you system for corrupt files. Also use a good antivirus software which is active to keep your system performing without an attack on the OS. Remove all unnecessary programs installed which you do not use all the time and clean up the drives. This will free up the space and make your system faster.If there is no response but the PC tends to work slower and occasionally hanging when a program is being executed then you might have to install the OS once again. Install the OS and then an antivirus before the drivers of the PC is installed.
Thank You for using Fixya
8/24/2011 7:03:23 AM •
HP Compaq...
Answered
on Aug 24, 2011
Voir toute la page en francais
Vous devrez exécuter une restauration de l'ordinateur et par la suite dans la configuration de récupération post, nécessaire sélectionner la langue que le français.
7/2/2010 8:37:09 AM •
HP Compaq...
Answered
on Jul 02, 2010
