20 Most Recent HP Compaq Business d530 PC Desktop Questions & Answers
2answers
Missing or invalid processor microcode
Missing or invalid processor microcode update. Please contact HP company for a new microcode update to support the new processor stepping
2/9/2019 5:33:27 PM • HP Compaq... • Answered on Feb 09, 2019
I have a d530 minitower
must be stinking XP and the F6 blunder. so why run XP, the virus magnet. i guess you meant something does not work and that Something (a secret) needs a DRiver. or you mean you are installing windows XP from scratch and when it gets lost finding SATA drives. (as XP loves to do) and then asks you to load the SATA driver using F6 key. then you look and there is no floppy there. upgrade to W7 XP and VISTA are not supported now.
12/14/2017 11:41:51 PM • HP Compaq... • Answered on Dec 14, 2017
2answers
Hello I have HP D530 PC.
We are here to help. Contact +18002044427 HP® for Consumer, Business and Enterprise technical support for HP products and services.
4/15/2017 9:15:57 PM • HP Compaq... • Answered on Apr 15, 2017
My computer wont start up. The power supply light flashes green when plugged in then red. But still nothing , can someone please help?
Try a Power Supply Unit (PSU) Reset: Unplug the electrical cable from the wall and the PSU (Back of Computer) Move the red voltage selector to the opposite position it is in and then slide it back. If you live in the USA 120Vac to 220Vac back to 120Vac After you have done this you can plug the power cable back into the PSU. Connect the power cable to the wall power. If the PSU is still serviceable it will no longer be blinking. 2c170cb8-7c41-4ef0-8a3f-ff232e57320e.jpg fd10abb2-6218-42f0-8857-b761fffbcecd.jpg
4/27/2014 7:05:59 PM • HP Compaq... • Answered on Apr 27, 2014
Hp d530 bios update 786B2
hi, go to hp site enter your model number(service tag if it has one) check for bios updates if one available use the hp bios update program. you may have to download a small program to allow this.will also check for any other updates for your hardware.
4/23/2014 1:22:35 PM • HP Compaq... • Answered on Apr 23, 2014
Install 1394 card to hp compac d530
4_14_2012_4_44_06_pm.jpgIf the slot looks like this one you can place any PCI card you wish to install. John
4/14/2012 4:45:11 PM • HP Compaq... • Answered on Apr 14, 2012
Backing up cmos settings
no you do not ..The bios settings will not be erased when you change the battery but will turn to default settings ..This is usually the setting used in this cases..change the battery (only in case it does not hold settings and file associations or the date and clock ..if does that it needs to be changed ) After changing it ..just reboot ..it will ask for F1 to go to setting and select the date and time ..and save changes with F10 and restart ..if it does not boot and it says it has no hard disk ..or not detected..it means you have a hard disk on sata bus..and you need to make some adjustments in Bios settings ..Open bios by pressing the del button on start or if it is a hap ...press F10 or what is indicated on screen ..and in there select the hard disk in boot sector as first boot device ..than in advanced settings look for it ..and under sata settings ..remove the ahci mode and use sata as ide or ide mode or ide compatible ..cause your system may not have the driver for ahci ..and this can be the only issue ..Let me know if you have any problems ..
12/18/2011 6:05:50 AM • HP Compaq... • Answered on Dec 18, 2011
My computer keeps on reminding to replace onboard battery?
it's telling you to replace bios backup battery, lithium ion button type, might be next to the bios chip on motherboard......
11/18/2011 2:44:01 PM • HP Compaq... • Answered on Nov 18, 2011
Now to reset administrative password
To create a password reset CD with Windows Password Breaker to reset your administrator password.
11/8/2011 6:36:55 AM • HP Compaq... • Answered on Nov 08, 2011
Pls. Help......... I have hp
hi,
do you hear a beeping sound when you do that? whats on your screen?
Here's how you explain LED Lights on your computer. See Link Below
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00274415
Hope this helps :)
5/11/2011 3:47:04 AM • HP Compaq... • Answered on May 11, 2011
2answers
HP d530 Audio Problem
Check to see if you do have the right driver installed.
Hook every thing in from the back of the computer, try the front if any. it may be recognized but is the wrong driver.
4/12/2011 7:06:46 PM • HP Compaq... • Answered on Apr 12, 2011
Iam having a problem with my computer HP compaq
try to change your processor with new one
3/17/2011 7:17:30 AM • HP Compaq... • Answered on Mar 17, 2011
Whenever I play a music
update your audio drivers and try using a diff audio program i suggest winamp or windows media classic
3/14/2011 2:52:03 AM • HP Compaq... • Answered on Mar 14, 2011
2answers
It says the system time
If you open the case and look at the motherboard you should notice a small, round, silver "watch" battery in a socket somewhere. This is the battery that needs to be replaces. Check this link for further instructions.
3/14/2011 2:24:01 AM • HP Compaq... • Answered on Mar 14, 2011
HP Compaq Business d530 PC Desktop Logo
62 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
backing up cmos settings
  • Computers & Internet
