20 Most Recent
Sennheiser PC 30 Headset Questions & Answers
I don't understand how to
Check carefuly to plug your green plug in the green slot out of three possible and the pink one in the pink one,then right click on your speaker icon in the down right corner of the screen and choose playback devices to find the device you are using by checking every device on the list by right clicking, "set as default" and testing if this is the device that gives soundthen right click on your speaker icon and go to recording devices. Use any program with microphone to do the same check by right clicking and setting "set as default".
Sennheiser PC 30 Headset not recognized on vista
My friend...
The sollution f this problem is to downliad this firware...install it and your headphones will be redy to play!!!
http://www.senncom.com/comm/icm_eng.nsf/root/support_faqs_pcusb_ms_vista
I have the Sennheiser HMD 280 PRO Professional
You have to wire the plug to eliminate the voltage sent by the sound card. I can't remember if it's the tip or the sleeve, so you'll have to verify with a volt meter. Use a 3 position plug to solder to the mic wires, just don't connect the wires of the mic to the one that has voltage on it
Sennheiser MM100 bluetooth not working
Yes I had the same problem.
Under some circumstances the MM100 freezes (didn't figure out when just yet).
It's a software issue inside.
Solution: open left speaker (the side with the charge connector and hence the battery).
Discharge the battery (or just short circuit for half a second) and it works again.
Sennheiser should built a reset button on these things.
