20 Most Recent
Sony Network Walkman NW-A3000 MP3 Player Questions & Answers
System error
get a tooth pick and poke the reset button located on the bottom of the device and it will be fine after that.
Problem with memory/erasing discrepancy
I did erase all from the device main menue after having copied them to my computer, that cleared the remaining files and recovered part of the memory. Then I did reformat from the same menu and recovered the entire memory! ;)
I have connected mySony Walkman
Are you transferring the music with the software that came with the Walkman or just Windows / Media player etc? This device may need you to use its own software in order to create a playlist that it will "see" so it knows where the music is. Some players are finicky like this.
Chris
Need to empty device
How do
download winamp free from winamp.com it will connect to your device when you plug it in. on the left hand side at the bottom will be your device click on the name and you can delete all the songs from there.
I have a sony nw
Have you tried to run the program in Compatibility mode? If even then it fails then you have just one option left: to create complete XP install inside your Vista and install the connection program in it.
Follow this
http://www.howtogeek.com/howto/11060/create-an-xp-mode-for-windows7-home-versions-and-vista/
