20 Most Recent Dell OptiPlex GX260 PC Desktop Questions & Answers
the PSWD1 jumper is there.
Dell OptiPlex... | Answered on Aug 23, 2018
Go to dell.com/support inter the service tag number and tell it to search for your drivers. Also update the BIOS after all updates are done restart your computer to insure the system updates.
Dell OptiPlex... | Answered on Nov 02, 2017
If you really must, I suggest you stick to Dell BIOS updates downloaded direct from their website (and make sure it's for you specific model number ..)
A failed BIOS update is the quickest way to 'brick' your motherboard ...
Dell OptiPlex... | Answered on Mar 30, 2016
This stuff is 'generic' .. just buy a tube off ebay (you don't need 'silver' paste untill you into extream overclocking and 5ml is more than enough for 1 CPU)
have you tried these..F1
F2
F10
DEL
ESC
Dell OptiPlex... | Answered on Jan 20, 2016
It will run but if you want smooth full graphics you will need to get a better video card. of course 4 gigs of ram is better then 2 but if you are running 32 bit windows then you are stuck with a max of 3 gigs of ram.
Dell OptiPlex... | Answered on Dec 03, 2015
U can try restoring the bios to its defaults. If that does not work all u can do is get whatever files you want off of the drive and reload the unit.
Dell OptiPlex... | Answered on May 25, 2015
Hold the ''c'' key down while starting the computer. The computer will boot from the CD.
As far as not being able to enter BIOS, it could be locked with a password.
Dell OptiPlex... | Answered on May 19, 2015
Go to the hp.com site and click on support and select Drivers. On the right side of the page is a link offering to let HP Detect my product. Click that and it should show all wireless devices available for the model you have. If your wanting to reload the driver, just click on each one (one at a time) and if it's the correct driver, it will load up and if not, it will tell you it didn't discover the device. No big deal. Just click on the next one till it recognizes your card and loads up!
could you please write out again what is wrong can not understand what you are asking,sorry.
Dell OptiPlex... | Answered on Apr 13, 2015
Luckily you had a Dell. Using your Dell Service Tag you can all the drivers you need. Just go to the Dell Support web site
Support Dell US
Select support by product
Enter you Dell Service Tag
Select Drivers and Downloads
You can also use the link to download User Guides or see the computers original configuration. Since it's a GX 260 you don't need to see if the desktop is still under warranty
Dell OptiPlex... | Answered on Apr 06, 2015
It Sounds Like The Software Is Messed Up So Badley That
The Only To Fix it Is To Re Partition And Format The Hard Drive And Re Install The Os! However You Need A Sepret Piece Of Software In Order To Do This! This Software Would Be On A CD Rom Disk And Is For The Brand Of Hard Drive You Are Using! Just Go In To The Bios Of The PC To Make Shure It Is Set Up To Boot From The CD Rom Drive
And Save And Exit The Bios Then Incert The CD Rom Disk
And Fallow The Instructions On The Screen!
Dell OptiPlex... | Answered on Mar 17, 2015
Hi Daiel,
Hopefully this will be the problem of the system memory module or the module slot. Try with changing the memory slot of same memory module or change the entire memory module. Its very old one right, so these problems may occur due to heavy duty done by the memory modules.
Dell OptiPlex... | Answered on Feb 04, 2015
first connect the "cat 5" cable to the dell's network card, the card has a square-ish hole with a little "cutout" in the top (for the cable's connector tab) the other end of the "cat 5" cable goes into the back of the router (you do have an existing router?) into one of the un-used square-ish holes (same cutout for the tab).
Then turn on the computer, see if the computer will "connect" to the router (that means it sees the router in computer-ish software).
IF that works then connect the router to the Modem (supplied by the "Internet Provider"... Then turn on the modem....
IF all goes well, your computer will now be able to connect to the existing internet.
Now for problems...
IF it seems to be connected correctly using the proper cat 5 cable, and it still will not work... turn off everything, start with the internet modem, then the router, then the computer... COUNT to 30 (1, 2, 3, 4... 29, 30) turn on the internet modem... count to 90 (1,2,3,4...90) turn on the router... count to 30 (1,2,3,4...30) turn on the computer... wait for it to fully boot, look down at the lower right of the screen and see if it can connect now.
IF it still doesn't connect, you may have to try another network card in the computer, or get a wireless USB "thingy" to connect to a wireless router...
Hope this helps...
Dell OptiPlex... | Answered on Nov 26, 2014
The full information, you can search yourself; that's like asking what drives over 30mph on a highway and please be complete.  Meanwhile all AGP x4 slots support 512MB videocards, if that's what you're asking.
Dell OptiPlex... | Answered on Oct 24, 2014
Because you lost the configuration of your computer when you changed the battery. You have to go into the setup menu and select the devices that your computer have.
Dell OptiPlex... | Answered on Oct 09, 2014
Dell OptiPlex GX260 PC Desktop Logo
916 questions posted
Ekse
Alun Cox
Thomas F. Schneider
View Most Popular
OptiPlex Dell
  • OptiPlex Dell
Most Popular Question
push power button get
  • Computers & Internet
