20 Most Recent Oster 76076-040 Hair Trimmer Questions & Answers
2answers
THE SWITCH IS BROKEN OSTER TITAN CLIPPER.
If the clippers are less than a year old send them back too your supplier, if not you can send them to our servicing department or alternatively fit a replacement switch.
7/11/2010 4:26:35 PM • Oster 76076-040... • Answered on Jul 11, 2010
4answers
OSter Titan hair clippers
Oster titan blades. I have had mine for 5 years.
Oil one is a little ball on the side of clippers push in with oil tip. Make sure your clippers are running for this. You also have to grease them once in awhile with clipper grease. You should have a front panel that has screws. open and grease put case back on. for cord you can try an oscar fix place or try and see if the company will replace if you have not had them long. hope this helps.
4/15/2010 1:09:38 AM • Oster 76076-040... • Answered on Apr 15, 2010
I had to replace the back of my 76, cord, switch
if your 76 clipper is a older model with a gray switch you install to black wire wrong. Now if this 76 is a newer model you have the tang position wrong. your best bet Contact [email protected] they can help you with step by step instruction.
3/30/2010 9:13:52 AM • Oster 76076-040... • Answered on Mar 30, 2010
Broken clippers
www.oster.com/ServiceCenters.aspx lista many service centers accross the country.
I suggest one like Shaver Service Center 5320 Cameron Road
Austin , Texas
78723
Phone: 512-454-5848
Fax: 512-454-9432
[email protected]
http://www.shaverservicecenter.com
Email them, or one like them with your special situation and I suspect they will help you with RUSH SERVICE.
Keep up the great work you are doing over there, and stay safe!
9/8/2009 6:48:35 AM • Oster 76076-040... • Answered on Sep 08, 2009
The cutter of the blade assembly barely moves. Oster A-5 Turbo
this pin or Post is moulded to the body of the clipper they only require replacement if you can move the post, alternatively there could be wear on the nylon drive lever or the gear try packing with clipper grease.
9/6/2009 6:06:54 PM • Oster 76076-040... • Answered on Sep 06, 2009
Oster clippers
Found another web site where some one had posted the information I needed. I just used Google search and found the information.
3/11/2009 11:47:03 PM • Oster 76076-040... • Answered on Mar 11, 2009
Greasing the oster titin
Just a few drops of light oil directly on the blades themselves. This should make a world of difference. good luck 3 in 1 oil will work sewing machine oil or somthing similar. I have also used some fancy spray lubes in the past with good results.
1/29/2009 3:19:27 PM • Oster 76076-040... • Answered on Jan 29, 2009
Where do i put the oil to oil the blades
When oiling clippers you want to have them running and tilted blade down toward the floor. You put about 3 small drops right on the running blades. Then wipe off excess oil with a towel. You dont want the oil running back into the motor of the clipper. You should oil them about every other use. Good Luck!
1/10/2009 2:43:26 AM • Oster 76076-040... • Answered on Jan 10, 2009
How do i change the blades
Have you tried having the blade running when you slide it back in?
1/9/2009 8:26:29 PM • Oster 76076-040... • Answered on Jan 09, 2009
I just bought a 000 blade for my oster classic 76 and the blade isnt cutting its pulling hair
Be sure to oil the blade and install it with the clipper running so that it seats correctly
1/30/2022 9:54:13 PM • Oster Health &... • Answered on Jan 30, 2022
Noisy, chattering Oster A5 clippers. What’s going on?
if theres a plastic screw on the side try adjusting it like the manual says to do
2/2/2021 8:48:50 PM • Oster Health &... • Answered on Feb 02, 2021
Oster A5 turbo 2 speed Pet Clippers
Send it back for refund. Nothing in a clipper should overheat like that. Buy the best, buy Wahl..Oster make kitchen small appliances. Wow, I just Googled these and they are $210! Looks like made for Pro use, however the overheating issue is a known fault mentioned here on Fixya and in reviews.https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk01wxC5WCeRaj1QnQ36Nj7aY94IU5g%3A1612122391802&ei=FwkXYLzEMK29ggfh8bmgCw&q=oster+A5+turbo+2+speed+overheating..
1/31/2021 7:56:44 PM • Oster Health &... • Answered on Jan 31, 2021
I'm looking for an owners manual for Oster electric knife and scissor sharpener model 522
eBay sale item may be similar to yours with a manual:https://www.ebay.com/itm/VINTAGE-OSTER-Double-Action-Electric-Knife-Sharpener-W-Manual-USA-Model-522-/153587369882For link below, registration is required, and I have not personally registered to verify it. Apparently a 1950's device that may need to be serviced or replaced. https://free-downloads.online/7711-0-c5e0c2f6/signup-blitz/#/theme=dark/c_bg={c_bg_enc}/z=51155/dp=2906786074.538571.44fa3ae453.33665.1c1e01e67e064c41c94abed63baaec57/q=Oster+knife+sharpener+manual/
10/12/2019 4:03:27 PM • Oster Health &... • Answered on Oct 12, 2019
Oster 76076-040 Hair Trimmer Logo
18 questions posted
Top Oster Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Marc Messenger
Level 1 Expert
jws1013
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Oster Health & Beauty
Most Popular Question
oster titan hair clippers
  • Health & Beauty
