20 Most Recent Oster 78950-100 Questions & Answers
0answers
0answers
I have the Oster model
Have you checked out hair salon supply stores, like Sally Beauty Supply. They will sell generic and brand specific blades for all cutters.
8/28/2011 11:30:49 PM • Oster 78950-100 • Answered on Aug 28, 2011
We have an Oster 78950-100-700 model and I dont'
The two screws of the blade guide are tightened completely. Adjust the tension between the blade and the blade guide with the large plastic screw on the side of the trimmer (this allows the blade to move rapidly from side to side). I plug it in at this time and when the cutting blade begins to move the clipper makes much louder noise. This is normal but it sounds like it is broken, it isn't. Adjust the cutter slightly past movement. You don't want it to bounce on the guide
8/28/2011 11:28:48 PM • Oster 78950-100 • Answered on Aug 28, 2011
Reattaching the blades
The blade (the small one with several holes) gets attached to the slide spring (the thin pieces of metal with a small gap between them), through the two diamond shaped holes, with tension on the slide spring keeping the blade in position. The blade guide, the large plate with only two holes, gets mounted with the two screws. The rough surfaces of both blade and blade guide face each other.
The two screws of the blade guide are tightened completely. Adjust the tension between the blade and the blade guide with the large plastic screw on the side of the trimmer (this allows the blade to move rapidly from side to side). I plug it in at this time and when the cutting blade begins to move the clipper makes much louder noise. This is normal but it sounds like it is broken, it isn't. Adjust the cutter slightly past movement. You don't want it to bounce on the guide.
8/28/2011 11:26:17 PM • Oster 78950-100 • Answered on Aug 28, 2011
I just recieved a new
ok the blade latch only holds the blade into place.
the hinge assembly which the latch sits behind needs to be open, there is a silver piece with two ridges on, place a flat bladed screwdriver behind the hinge and this will lever open you can then slot the blade onto the hinge and close shut with the clipper running.
8/22/2011 5:05:08 PM • Oster 78950-100 • Answered on Aug 22, 2011
Never used. Bought a month ago. Tried it today.
try contacting your supplier or send the to an oster service station such as www.angliaclipperservices.com
9/16/2010 10:18:56 PM • Oster 78950-100 • Answered on Sep 16, 2010
Won't cut hair & is a new blade
Make sure you have "3 in 1" oil nearby and oil the blades before and after each use. Use an old toothbrush to clean the blades while wet with oil and then wipe the excess oil and crud off with a paper towel. Store in a dry place away from bathroom humidity. I've found that the cheap ones just don't do the job and a while back, I decided to pony-up for a decent one. So, the reality is, cheap ones don't cut that well and even the best ones won't cut well if you don't keep them cleaned, oiled and rust-free.
6/13/2010 6:18:34 PM • Oster 78950-100 • Answered on Jun 13, 2010
Oster #10 blade will no longer cut my dogs hair
Need to be sharpen by a professional mannyssharpening.com
3/30/2010 8:06:45 AM • Oster 78950-100 • Answered on Mar 30, 2010
My 78950-100 will not cut my dogs hair
The clipper that you purchase dose not have the power to cut the Dog fur, You need a Andis Xcel 2 speed with a # 10 clipper blade. www.mannyssharpening.com this clipper is quiet and has power. [email protected]
3/30/2010 6:26:37 AM • Oster 78950-100 • Answered on Mar 30, 2010
If my Oster cliper 78950-100
clipper sharpening is a much cheaper option and they can be restored to there original condition.
9/4/2009 5:18:47 PM • Oster 78950-100 • Answered on Sep 04, 2009
I just bought a 000 blade for my oster classic 76 and the blade isnt cutting its pulling hair
Be sure to oil the blade and install it with the clipper running so that it seats correctly
1/30/2022 9:54:13 PM • Oster Health &... • Answered on Jan 30, 2022
Noisy, chattering Oster A5 clippers. What’s going on?
if theres a plastic screw on the side try adjusting it like the manual says to do
2/2/2021 8:48:50 PM • Oster Health &... • Answered on Feb 02, 2021
Oster 78950-100 Logo
Popular Tags
23 questions posted
Top Oster Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Marc Messenger
Level 1 Expert
jws1013
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Oster Health & Beauty
Most Popular Question
just recieved new
  • Health & Beauty
