20 Most Recent
Dell DJ Ditty MP3 Player Questions & Answers
Hi!! I have n Dell
Hi...download an app called driver booster 4 from here http://www.iobit.com/en/driver-booster.php and run it...it should install any and all drivers/software you need in your dell...should you need any help with this app just ask as it is very good! Thanks for your enquiry,
Dell DJ Ditty is "dead"
good day!
try removing battery or resetting it. after that format your mp3 using your computer and it should be working after you did that.
thank you for using fixya
CHARCOIS
The device cannot be detected
Hi boyzrock 289
Try this solution to your problem.
Go to Device Manager
To get to Device Manager you will:
Right click on My Computer>Properties>click the Hardware Tab>Device Manager.
After you are in Device Manager look for your MP3 player or Unit.
Here you should see no "Yellow" exclamation points.
If you do they they are telling you that you have a device conflict.
If you currnetly have your unit plugged in, you may notice the "unknown device" which would be your Player or Unit.
If you unit has an exclamation point by it, then you will need to click on it and delete it.
After you remove all devices with conflicts then click on refresh and search again for your MP3 player/Device.
The computer should install your device this time and solve your problem with connection of the MP3 player/Device.
Please take time to rate me thumbs up.
The mp3 player won't turn
Make sure the lock button on this player is not set. Try recharging the batteries. This seems like
a pretty old model the battery may of bit the dust. I have a phillips thats very similar to this one and
it's about 6 years old. In the US you can get a similar model in features for less than 20 bucks.
Can the battery of a
Hi, You can buy the battery at any mp3 player accessory store around your area, or you can other on line through eBay.com and Amazon.com.
How to Change the Battery in a Dell DJ-20..
The DJ is an MP3 player developed by the Dell computer company. Like any other battery-powered electronic device, the battery will likely give out and stop working at some point. If this happens to a Dell DJ, the two main options for fixing it are to send it to Dell to have the battery replaced, or do it yourself. You can save a great deal of time and money by replacing your own Dell DJ battery.
Things You'll Need:
* Micro screwdriver set
* Tweezers
Instructions
Hold the Dell DJ upside down so you have a clear view of the bottom.
Wedge a flat-head micro screwdriver in between the black plastic piece and the USB port on the bottom of the DJ. Pry the plastic piece off and set it aside. You should now see four tiny screws on the bottom of the DJ.
Remove the four screws with a micro Phillips-head screwdriver. Set the screws aside in a safe place.
Pull the metal plate out that was held in by the screws. You may need to use a screwdriver to help pry it out. Once removed, you will have access to the inside of the DJ.
Locate the small red cable with a white plug on the inside of the DJ. Carefully pull the plug out. If you cannot grab the plug with your fingers, use a pair of tweezers to do so.
Grab the battery with a pair of tweezers and pull it out. The battery is the thin rectangular piece that the red cable is attached to.
Insert a new battery where the old one was. Plug the battery into the motherboard where the first battery was plugged.
Reattach the metal plate on the DJ with the four tiny screws. Snap the black plastic piece back on to finish the job.
First off my DDD 512 MB MP3 player no longer has a
have you let it get wet?.... if not, let it die and try again.... there is a hole next to the headphone plug in, it's a reset.... if it don't work, then have it fixed.... i have had mine since 2006 and had no issues.
How do i take off
Plug up your dell DJ Ditty MP3 Player
Go to my computer and click on your storage device
You should be able to manually delete what music you want off
How do i put music on the dell dj ditty 512mb
Connect the device to the PC open "My Computer" and "Computer" then look for the device name or any removable device if you can find it then open it and then copy the music files to that drive and remove it.
How to safely remove dell dj ditty
as long as the device is 'idle' (your not dragging and dropping, or doing anything to it like updating firmware, or syncing with a media player) you can just pull it out of the usb port. or to play it safe, right click or control click for mas, and select eject.
