20 Most Recent Fujitsu Siemens SCALEO 600 (FSP:83C005617) PC Desktop Questions & Answers
SCALEO P D1840
2/20/2015 8:47:54 PM • Fujitsu Siemens... • Answered on Feb 20, 2015
Which CMOS battery for iqion PC?
Most PC backup batteries are a model cr2025. When you take the side off and locate the battery its stamped on the back and held in with a spring clip. If you pop the battery while the main power cable is in it will keep the bios settings. If not, you will clear the bios...so if the bios is customized especially to boot a certain way it may not boot after the battery has been changed.
5/3/2014 7:18:56 AM • Fujitsu Siemens... • Answered on May 03, 2014
0answers
0answers
Seimans scaleo will not turn off unless i turn off at power switch whenon i get nothing
try to remove unwated application starts with windw or at startup. it will help you.
11/21/2013 11:16:39 AM • Fujitsu Siemens... • Answered on Nov 21, 2013
0answers
2answers
I want to download sound
on this page
http://ts.fujitsu.com/support/downloads.html
type sclaleo 600 for searh
you will
be redirected
to drivers download page
8/15/2013 7:50:52 AM • Fujitsu Siemens... • Answered on Aug 15, 2013
How to conect led pow cables to scaleo motherboard
I just follow the pins and remember that you connect long ways..try this might help
4/4/2013 6:43:30 PM • Fujitsu Siemens... • Answered on Apr 04, 2013
I need a recovery disc for a Fujitsu-Siemens Scaleo 600 desktop PC
I wouldn't worry that you won't get it running without a Recovery Disk.Just wanted to state that right off the bat.You can buy a fresh, new Genuine copy of Windows XP, and use it.Jus sayin'.[Microsoft makes one Master disk. From it all GENUINE copies are made, and sold to the consumer]Don't know that much about Fujitsu Support, as to obtaining the Restoration Disk, for THAT computer.Guess there's only one way to find out, huh?That apparently would be to choose THE country you are in, as support is country specific.Looking at this from a USA perspective,http://www.fujitsu.com/us/contact/Call 1-888-385-4878Have to try that tomorrow. It's presently 9:52PM, lol!No wait! Hold the phone.............Just called 1-888-385-4878It's a 24 hour line.Just talked to the representative on the phone.I didn't have the Serial Number, naturally; but did get basic information.The Serial Number is needed for specific information.[NOTE* Do NOT give out the Serial Number on a worldwide forum.ONLY give to an authorized Fujitsu representative ]From what I understand it does depend on the disk you need, and the type of computer..IF, I understand correctly, the disk (DVD) is $12, plus the shipping and handling.Sounded like the maximum cost is $28. (USD)Indicated a 2 to 3 day ship, and sent by Fed Ex.Best method of course is to just call them yourself.If I may, would appreciate hearing about how it was, for you to obtain the disk.Will increase my knowledge.[A LOT cheaper than a fresh, new Genuine copy of Windows XP, too! Lol! ]For additional questions please post in a Comment.Regards,joecoolvette
3/8/2013 4:14:06 AM • Fujitsu Siemens... • Answered on Mar 08, 2013
Fujitsu ASTA12LCC A/C won't turn on ?
Wrong category
1/16/2013 2:32:36 PM • Fujitsu Siemens... • Answered on Jan 16, 2013
My audio device
If your computer came with a motherboard disc the sound drivers could be on it Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers. Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there. Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it. If you don't have a motherboard disk you will have to download the drivers http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for tick in either box for windows software or all software IE: motherboard name audio driver you might have to try a few times to get it right If his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable) also you might check The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good with no dust as dust causes static electricity clean your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer Hope this helps. http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: motherboard name audio driver you might have to try a few times to get it right Hope this helps,
12/24/2012 8:41:57 PM • Fujitsu Siemens... • Answered on Dec 24, 2012
How to take the hard drive out
on a desktop computer wear an antistatic earth strap remove the power lead from the power in put on the computer remove the side panels on on our computer you will see 4 screws 2 either side unscrew these then remove the electrical lead and the sata lead remembering where these are located slide the hard drive out then put your new sata hard drive in placing the leads back to there original position then tighten the screws (do not overtighten)
http://www.ehow.com/video_4978913_install-internal-hard-drive.htmlutube video install a second ide hard drive
10/16/2012 4:38:31 PM • Fujitsu Siemens... • Answered on Oct 16, 2012
Scaleo P drivers utilities cd wanted
Get onlineand got to www.google.com In the google search box type: "FujitsuSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.
4/24/2012 1:13:01 PM • Fujitsu Siemens... • Answered on Apr 24, 2012
I needs parts for my scaleo 600
Try eBay or any computer store. CD's are standard and universal. Just make sure you get one that has the same interface (IDE or SATA) as you have.
4/9/2012 1:26:06 PM • Fujitsu Siemens... • Answered on Apr 09, 2012
2answers
I want to install a
It might be difficult to find, but purchase an IDE type drive. Your system does not have data ports that can handle the newer SATA drives.
Ask that the store test the drive, if possible, as it could have been a customer return!
9/13/2011 11:17:46 PM • Fujitsu Siemens... • Answered on Sep 13, 2011
Scaleo 600 how can
Plug your modem up to your phone line & plug in the power cord. If you are using an ethernet cable its should plug into the modem and into your computer. If you are connecting wirelessly, make sure you card has a wireless network card or that you have a wireless adapter. If it still doesn't work you may have to call you internet provider to make sure the modem settings correct.
9/11/2011 1:17:01 AM • Fujitsu Siemens... • Answered on Sep 11, 2011
While booting the tower, it
Those are beep codes. Going to need to figure out what kind of motherboard it is, and look it up here: http://www.computerhope.com/beep.htm
The sound of hardware failure is too happy, imo.
7/25/2011 12:07:39 PM • Fujitsu Siemens... • Answered on Jul 25, 2011
Fujitsu Siemens SCALEO 600 (FSP:83C005617) PC Desktop Logo
99 questions posted
Top Fujitsu Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Fujitsu Computers & Internet
Most Popular Question
need recovery disc fujitsu siemens
  • Computers & Internet
