20 Most Recent
Sony Walkman D-EJ010PS Personal CD Player Questions & Answers
I have a Sony Psyc CD Walkman D-Ej010 and I will
There may be a couple of reasons why a NO DISC , DISC ERROR or INSERT DISC error may appear in the display of your CD player. Try doing the following steps to troubleshoot why the error is displayed:
- For disc players with a HOLD switch, make sure to move the switch to the OFF position.
- Verify that the disc being used is supported by the CD player. NOTE: CD players do not support VCD or DVD discs. In addition, some CD players do not support CD-R or CD-RW discs that are created by a CD burner. For information regarding disc compatibility with your player, refer to the operating instructions supplied with the product
- Ensure a disc has been inserted into the player. Make sure that the disc is inserted correctly, with the playback side of the disc facing down on the disc tray.
- If the disc still does not play, attempt to play a different, commercially-produced disc.
- NOTE: If more than one of the commercially-produced discs do not play, verify whether the discs are extended-length discs. Some players are not able to play discs where the recording exceeds the standard 74 minutes. If the recording of the disc is longer than 74 minutes, it is possible that some of the specifications of that disc were compromised and therefore, the CD player will not recognize that disc.
- If the disc is dirty with fingerprints or smudges, or if the disc is scratched or broken, the CD player may not recognize the disc.Clean the disc using a soft, dry cloth.
- Properly reinsert the disc into the player.
- Attempt to play the disc again.
- Only press the PLAY button once. If the PLAY button is pressed more than once, the disc may stop playing.
- If the disc is still not recognized, remove the disc and leave the CD player powered on for approximately one hour to resolve the possibility of moisture condensation inside the player.
- Please use a Lens Cleaning disc and check if that helps.
If the issue persists, please click hear to locate the repair facility near your area.
Thanks for understanding. Please let me know if you require any clarifications.
I have a Sony STR-AV770 receiver that has stopped
your question depends on how good you are at electronic diagnosis (symptom diagnosis) and how adept you are at removing and installing electronc components. first you have to determine why the amplifier has stopped working on the left channel. Make sure that the problem isn't a simple one, take the speakers off the right side and hook them to the left side and see if you get sound. If you do,, then the problem is the left speaker or left speaker wire. If you don't get sound then tyr taking the input that feeds the right channel and pluggin it into the left channel and listen for sound, if you get sound now the problem was the signal from your source not being sent down the left side.
If it still doesn't work you need to move inside the amplfier, but first, get close to the back of the amp and give a sniff, do you smell anything (a pungent burnt wire or rubber smell) if you do, the the chances are good that some components have burned out. Do you recall having a shorted speaker wire on the left side? shorted speaker wires are notorious (especailly older equipment) for burning out the final amplifer stage. If this was an expensive amp it might be worth fixing, if its not worth much then maybe you should consider religating it to use as a monophonic amplifier (one channel) you could use it to power a sub woofer in a hibryd stereo or surround sound system.
I don't know what more I can tell you at this point. If you go through the steps I outlined, and want to tell me the result I shall be glad to respond and maybe give you another direction to head in. good luck and I'm glad you are adventruous enough to want to try.
Volume knob of sony icf- sw 7600gr radio stuck on high volume. Cant be reduced
Recently I found a Sony ICF 7600GR with same issue.... Radio runs full volume.. can't be controlled... Found a SMD package capacitor C252 ,1uf was short.. 1.2Volt was missing on pin number 14 of IC 203
Check these voltages of IC 203 ( CXA1522P)
Pin -15 Voltage is 1.3V
Pin -14 voltage is 1.2V then" No/low Volume".
Pin -14 voltage is below 0.5 then "Full Volume ".
By varying volume control (RV204 , 50K) , Pin number 14 of IC 203 must vary between 0.3V to 1.2V.
10/14/2023 10:34:30 AM •
Sony Audio...
Answered
on Oct 14, 2023
