20 Most Recent
TCL LE32HDF3300 32 Inch LED LCD HDTV Questions & Answers
What is the code for TV remote so I can program dish network to the tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Picture size
from remot press menu > picture menu> contrast> 9735 then service code wil open u can select & adjust
Blowing fuse
There is a short circuit in its main power supply regulator board. Check and replace damaged component/s at this board. Never put a fuse and switch ON the TV, until all the faults have been repaired. It might make things wrong.
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.
Tcl l40f10f
try update your TCL TV firmware by current update version file from USB stick
https://electronics-tricks.blogspot.com
