20 Most Recent
Gateway GT4016 Desktop PC Questions & Answers
Re installed the operating system to cleen of a
nvida.com then go to driver downloads look for your card and so on. You should try this go to your device manager go to the network card right click it and hit property's make sure that its is enabled and make sure its in the list lol. If it is you can click the uninstall button restart the comouter when windows starts it willl tell you that it found new hardware tell it to let windows install the best drivers for it that has worked many times for me
MY Gateway GT4016 Will not start anymore, i first
Make sure all fans are running power supply one to hehe Maybe a bad power button? I had a gateway that did some thing very close to that because the cpu fan was not turning and a hp that did that because the power supply fan was not turning. Thats where I would start then make sure the mem is seated good and not bad you know the drill ;) if you replaced the power supply with a factory replacment it should be a voltage or wattage problem. Might also try a hard boot the power plug take the cmos bat out hold the power button down for 20 or 30 secs some people say to leave the cmos bat out and try to fire it up. I know that works on some laptops but I always had better luck putting it back in for desktops cant hurt to try it. If you have two ram sticks in it pull the # 2 one and try to fire it up if nothing changes swap the # 2 one with # 1 leaveing slot 2 open and try it that will tell ya if it is a bad ram stick I dunno just my two cents hope it helps
I clean my pc inside but now not turn on only the
just as simple as some thing got wiggled loose. I would make sure all ram is seated well cpu power plug as well as all the plugs on the mother board and drives are pushed all the way in. Make sure video card and wireless cards are all seated good. If the video card has a cooling fan on it as well make sure the power cord to it did not get wiggled loose. Make sure the the plugs from the power supply to the mother board are plugged in good and tight. But if it was working and you just blew it out has to be some thing loose
I have a Gateway GT4016 Desktop PC im trying to
almost all gateway have all of your restore to factory default on a drive that is hidden on the hard drive. All company's use a different key to do this but I always start with f5 start the comp and hold f5 down and the system restore program should pop up. If it is not f5 it will just beep at ya. Then just do the same thing over and over starting with f1 all the way to f12 until you find the right one. but I always try f5 and f8 first hope that helps
Computer fans come on wide open drive light blinks
make sure the hard drive cable is plugged in good and the power button is as well. then unplug the power cord from the supply and take the cmos battery out. before you plug it back in hold the power button in for about 30 seconds. Put the cmos battery back in make sure all of your ram is seated well as well as video and wireless cards. Plug the cord back in and give a shot Might just need a hard boot.
I need the ethernet driver
It should have them already on your restore partision I would go to device manager go the ethernet net card uninstall it restart the comp it should tell you it found new hardware and then tell it to look for the best driver for it
My Gateway GT 4016 starts
Might be better to go with a new one by the time you have the money and effort into it be about the same I would think and get a newer comp upgraded mem and such just a thougth
Don't know where to attch all plugs for gt4016
what plugs? All of them? Power supply plugs should be marked as well as different. Hard drive cable gos in the # 1 slot dvd and so on go in slot #2. If the cpu fan is installed some have a power supply plug others plug in to the mother board. Most of the time it will be close to the cpu and only a two prong plug. Most of the time all the of the wires will be marked in small writing on the plug itself and its as simple as getting a flash light and match the plug with the socket on the board that are almost always marked
Does not boot up, fans
Instructions
When you press the Power button to start the boot process, the LED lights glow while the computer verifies that there is sufficient electrical power to activate the hardware.
Effect
& Solution: When you press the power button, the LED lights on the
computer do not glow or the LEDs blink briefly and then stop. There is
no sound of the fan or hard drive spinning, and the screen remains
blank. The computer will not start if there is insufficient battery or AC adapter power.
The BIOS queries various hardware components used for the startup boot process.
Effect
& Solution: When you press the power button, the LEDs glow but
there is no fan or hard drive sound. The LEDs may glow briefly and then
go out.
Or
The LED lights blink, stop, and then blink a
second or third time, but there is no sound from the computer and the
screen remains blank. The sequence of the blinking lights indicates a
specific error code.
Or
A series of beeping tones is heard. The sequence of beeping tones indicate a specific error code.
If
a hardware component has recently been replaced, or if the PC has been
jarred or shaken, there may be a loose connection to the memory chips
or hard drive which prevents the computer from starting.
The BIOS loads the basic input (keyboard) and output (advanced LEDs / display screen / boot drives) devices into memory.
Effect
& Solution: When you press the power button, the LEDs glow, the fan
or hard drive sounds, are heard, but then the boot process stops and a
black screen - with an error message - displays.
The boot check has detected a communication error or conflict with a hardware component that must be corrected.
The BIOS loads the Windows operating system and starts the services
that allow low-level control of all of the background operations.
Effect
or hard drive sounds, are heard, the HP or Compaq Logo displays on a
black screen, but then the boot process stops and a blue screen - with
The boot check has detected a hardware driver error or a software conflict that must be corrected.
Control is transferred to the Windows loader to initiate the display of the advanced settings in the Windows environment.
The Windows logo displays during this step.
Effect
& Solution: When you press the power button, the computer performs
all the steps in the boot process, but after the Windows Logo displays,
the moving Windows progress bar or the rotating cursor stops moving and
the boot process stops.
An error message may display on a screen with the Windows logo. In some instances, there is no specific error message.
Or
A black screen appears and the computer attempts to restart.
The Windows self-check has detected a software conflict that must be corrected.
Getting detecting array message
And what else? If the system just hangs at detecting it's expecting to find an array of hard drives attached to the system. Do you have an array that it can boot to? Does it load the OS finally? Was it working before? Did you make changes to the bios ro the array controller bios?
Ktbc51glf vs ktbc51g
There are differences, but you should be good either way. For general use, you probably will not notice any differences.
Boot bio
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating systemgateway is F2 key Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
