20 Most Recent GE DVLR223 Dryers Questions & Answers
Sounds like you have bearings problems that need need grease. Normally the drum rests on two separate bearings up front and one located at the drum center at the rear. Since you know how to take it apart you should be able to locate the bearings. A mall amount of general purpose grease will do the trick. The scatching noise may come from loose object floating around, may be a shirt button ? investigate.
Good luck and good repairs. A dryer repair is not too difficult since you have already checked to condition of the belt...Here an extra tip for the performance of your dryer, always clean the screen air filter with soap an water to remove the invisible screen deposit by the Fabric Freshner Sheet also called Fleecy. This will allow air flow to exhaus the dryer more freely.
GE DVLR223... | Answered on Aug 21, 2017
Regular heat is hotter and sould be a shorter run time.
GE DVLR223... | Answered on Aug 06, 2017
bad drum bearing, bad drum teflon pads or both possibly
or both possibly or in combination the belt could need replacing
& if your not sure get a service tech so you dont do more damage
GE DVLR223... | Answered on Feb 09, 2015
you'll have to call in a tech to check it out or replace the dryer,nobody can answer that question without being there and checking the dryer with a meter,if the wires from the timer touched metal and i can't see how that happened unless someone worked on it without unplugging it you could have cooked just about any wire or part that those wires go to but then again you could change the timer and it could work but you have to check it with a meter first,that timer cost around 140 dollars,to much money to just guess at.
GE DVLR223... | Answered on Nov 23, 2013
the model you sent is for a g.e. electric dryer
Most likely you have a burnt element....A good handy man could replace the element fairly easily.. Cost of a new element about $50-$75
GE DVLR223... | Answered on Nov 08, 2013
Get a piece of hose and listen to each bearing. The hose should help isolate the problem.
GE DVLR223... | Answered on Oct 23, 2013
The fuse is located on the heater element which is bolted to the back wall behind the drum.
I have several home movies and repair pix on my DIY blogpage:
PAW PAWs DIY GE HOTPOINT DRYER Repair page
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
GE DVLR223... | Answered on Dec 02, 2012
Does the heat start and stop or does the drum?
GE DVLR223... | Answered on Nov 04, 2012
GE DVLR223 Dryers Logo
141 questions posted
Top GE Dryers Experts
John Tripp
John Tripp
Marc Taylor
Are you a GE Dryer Expert? Answer questions, earn points and help others
View Most Popular
GE Dryers
  • GE Dryers
Most Popular Question
hotpoint tvm570p making dreadful noise
  • Dryers
