20 Most Recent Panasonic KX-FL611 Plain Paper Laser Fax Questions & Answers
6answers
"Call Service 3"
if doing menu #9000*550 did not solve the problem for call service 3, it is better to call your panasonic service center.
the problem is in fuser unit. the thermistor maybe dirty or damage. careful to touch the fuser unit for it is really hot.
7/24/2018 8:58:48 AM • Panasonic... • Answered on Jul 24, 2018
7answers
Call service 3 panasonic kx-fl612
hello sir i have panasonic fax kx-fl 612 error code is call service 3 pls help us how i can run my fax plz
1/8/2017 2:51:39 PM • Panasonic... • Answered on Jan 08, 2017
2answers
Panasonic call service 3 kx-mb773
sir i have panasonic fax kx-MB2030 it come call cervice3 error i try #9000*550 but it not work
7/28/2016 6:22:49 AM • Panasonic... • Answered on Jul 28, 2016
2answers
Drum life over and i changed the drum and tonner
drum life over
replace drum
2/28/2016 6:43:08 AM • Panasonic... • Answered on Feb 28, 2016
0answers
Callservice3 pansonic kx-772
Call s3 means abnormal fuser unit. although you found jammed paper inside you have to replace fuser unit.try once to reset with the code. if unit seems became OK. if not 1.disconnect power.2.remove the bottom cover.3.dis conn.2 thick cable connectors(fuser lamp) and small white connector(thermistor)4.turn up right & remove 2 long screws 5.replace the new unit.6.press#9000*529 start.(new installation reset code) Remember these procedures must be done by a qualified technical person.(high voltage & extreme temperature area)
10/6/2014 5:22:16 PM • Panasonic... • Answered on Oct 06, 2014
I CAN'T SEND FAX WITH EXTENSION NUMBER
Generally if you wanted to send a fax to a facsimile which is connected to an extension.you must dial only the direct line number and ask operator to transfer this call to fax (wanted extension).After you heard the fax tone you can push start button. If the fax machine full-time connected to same extension & dedicated direct-line there only for faxing,we can program the pbx for automatically transfer the incoming fax or call to that extension.so outsider have to dial only direct fax number without ext no. Only Panasonic PBXes having a unique feature if i'm wright if it detect fax tone from any direct line it will automatically transfers towards fax extension.
5/30/2014 2:04:27 AM • Panasonic... • Answered on May 30, 2014
2answers
What call service 3 in Panasonic kx-mb1900
CALL SERVICE 3" means that the temperature of the fuser does not rise up to or exceed a constant temperature. The temperature is monitored with the thermistor inside the fuser and detected with the voltage input into IC 300-D19
4/30/2014 6:30:06 PM • Panasonic... • Answered on Apr 30, 2014
2answers
Error messgae
sir i have panasonic fax KX-MB2030 call servic 3 error i try #900* 550 but it is not work
3/3/2014 5:15:31 AM • Panasonic... • Answered on Mar 03, 2014
0answers
0answers
Drum life over replace drum
reset drum code menu # 9000 * 672 2 start
2/3/2013 8:55:06 AM • Panasonic... • Answered on Feb 03, 2013
Panasonic fax kx-fl 612 error
how to reset the machine
11/26/2012 6:37:22 PM • Panasonic... • Answered on Nov 26, 2012
My mchin panasonickx_fl611 i lost my cd driver
try" driver genius" you can find it on pirate bay for free. then if you like the program buy it and support the guys who created it. peace.
8/3/2012 3:14:19 PM • Panasonic... • Answered on Aug 03, 2012
How activate auto answer?
1 Press {AUTO ANSWER} repeatedly to display the following.FAX ONLY MODE 3 RINGS The display will show the ring setting in FAX ONLY mode. The {AUTO ANSWER} light is ON.2 If you wish to change the ring setting, press{A} or {B} repeatedly to display the desiredsetting, and press {SET}.How faxes are receivedWhen receiving calls, the unit will automaticallyanswer all calls and only receive fax documents.
3/8/2012 10:45:49 PM • Panasonic... • Answered on Mar 08, 2012
Panasonic KX-FL611 Plain Paper Laser Fax Logo
67 questions posted
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Office Equipment & Supplies
Most Popular Question
call service 3 panasonic kx fl612
  • Office Equipment & Supplies
