20 Most Recent
Braun bn0087 radio controlled black bn0087bkbkmhg Questions & Answers
Watch tells wrong time however many times io reset
Best thing you can do is download the instruction sheet from braun-clocks.com. Go to bottom left of page and click on Manuals search, then enter your watch model number in the box.
You need to calibrate the hands, particularly if you've changed the battery. Read the instruction carefully, it's a bit involved but it will solve your problem.
Braun bn0095 watch battery replace
"For servicing and repairs, the removal of the access screw on the back of the watch gives access to the stem release catch; after removal of the crown and stem, pressurised air is inserted to blow-out the crystal. Thereafter, the entire movement, together with the dial and hands are easily removed from the top. Experienced watchmakers with the necessary equipment should only perform this operation and the removal of the access-screw by any other persons without the required expertise is highly discouraged."
Braun BN0087GYSLMHG that is always reading 1 hour ahead of britsh time
Press button B for 2 seconds and second hand will move to show current time zone; 12=London, 1=Berlin, 2= Helsinki. press button A to cycle through time zones till you get the zone you want, then press B to confirm. Summer and Winter are changed automatically, contrary to the previous rubbish....I mean answer!
I would like to ask I have one Bulgari watch
First test is very simple: how does it look? Is it an existing model on sale, many times you will find new creations on marketplace which still needs to be invented by Bulgari themselves.
See the finish, is it correct. Figures, logo, etc. How does it feel, smooth, not too light, how does the crown works (solid) and the brace/strap, no rough edges on the case?
If you don't feel ashamed go a dealer and ask if this is genuine!
Numbers on the back say nothing, these are copied as well like software license key.
Check this site: www.bvlgari.com
Manual notice lost
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals.Rate me, please
