20 Most Recent
Panasonic PT-LB50U Multimedia Projector Questions & Answers
How to do lamp reset on panasonic pt-lb50u projector.
To reset the lamp hours, turn on the projector. Then press Menu and use the Up/Down arrows to highlight Options. Press Enter then highlight Lamp Runtime. Press and hold Enter for 3+ seconds until the Lamp Runtime screen is displays. Press the Power button (any other button cancels the reset). When the Power button LED turns red, unplug the power cord to the projector. You can either use the remote or the controls on the projector. Reconnect the power cord after a few minutes.
The reset instructions are on page 62 of the user manual. The manual is available from Panasonic here:
https://support.panasonic.co.nz/docstore/PT-LB50U%20Operating%20Instructions.pdf .
I hope this helps.
6/18/2016 10:34:49 PM •
Panasonic...
Answered
on Jun 18, 2016
The projector lamp does not turn on
I have done this on several of our PT-LB50U's with sucess every time.Remove lamp cover and lamp.Then remove top of case by removing 6 screws on bottom.Remove metal shroud that would cover lamp 2 screws and remove 2 screws that hold lamp plug and move it away.You will see a little blue lever for saftey switch move it back and forth from top and bottom put back together and should turn on.
9/15/2013 7:45:08 AM •
Panasonic...
Answered
on Sep 15, 2013
I have a panisonic pt-lb50ntu Projector. It will
Is the picture a perfect rectangle shape on the screen. If not then either adjust the angle of the screen, or use the keystone function on the menu to correct it.
Does it still not focus correctly after doing this
3/16/2011 1:51:19 PM •
Panasonic...
Answered
on Mar 16, 2011
The projector turned itself off
There are three temp sensor inside the projector and now your projector need full service but if the air filter becomes clogged with dust, the internal temperature of the projector will rise, the TEMP indicator will illuminate and the projector's power will turn off (the TEMP indicator will flash after the power is turned off) The air filter should be cleaned every 100 hours of use.
If you clean the filter with a vacuum cleaner to clean off any accumulated dust. then your projector working normally
1/25/2011 12:39:09 PM •
Panasonic...
Answered
on Jan 25, 2011
After changing the bulb image will not come on and
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
1/21/2011 2:20:55 PM •
Panasonic...
Answered
on Jan 21, 2011
Panasonic PT LB50NTU - LCD
The Panasonic projector PT-LB50NTU or E have two type of data inputs.
One is
RGB or VGA cable and second is VIDEO cable. If your
IMAC have video or vga output than you can connect.
Two type of cables witch are using with projector
1/21/2011 12:27:29 PM •
Panasonic...
Answered
on Jan 21, 2011
How to invert picture?
All you need is in the manual.If you dont have a manual ,
check their website and do a search on your model number.
Download is free.
10/11/2010 11:41:28 PM •
Panasonic...
Answered
on Oct 11, 2010
