20 Most Recent GE WBVH6240F Front Load Washer Questions & Answers
ck the plastic fins in basket for broken/sharp areas
GE WBVH6240F... | Answered on Aug 27, 2018
Clean filters to the pump
GE WBVH6240F... | Answered on Jan 27, 2018
Unplug electrical cord, wait one minute then plug back in. Sorry this is all I can tell u as I cannot find a parts diagram anywhere on Internet, not only is LG not helping u they don't want anyone else to help either by keeping their drawings secret. You might try sears partsdirect.com and talk to tech.
GE WBVH6240F... | Answered on Jan 16, 2018
I have notice this problem with a lot of front loaders. I would check the manufacture warranty to see with is covered and if you bought an extended warranty, use it, keep your receipts for your previous purchases.
GE WBVH6240F... | Answered on Dec 11, 2017
If I had this problem, here is how I would approach it.
Start by finding and writing down the complete model and serial number.
Go to "SearsPartsDirect" web site and type in the make and model of the machine.
When the schematic comes up , look closely at the pictures and see if there is a drive belt on your model.
If so, I would start with that being the problem.
It should be slipping.
Replacing it is a pretty big job, it needs to come all apart.
Could be because the machine is overloaded.
I do not mean you have too many clothes in it, but that could be the case.
Start by putting a half load into the machine and see if it still does this.
Remember also, heavy clothes full of water can stress even the strongest model.
God bless your efforts.
GE WBVH6240F... | Answered on Nov 16, 2017
Yes very normal in a front loader for clothes to be dripping wet but you may see little to no standing water.
GE WBVH6240F... | Answered on Nov 02, 2017
doesnt this model have the cancel button by the start button.......if so........switch on then hold cancel for 10 seconds...........
cheers
GE WBVH6240F... | Answered on Jul 24, 2017
that would be the bearing and housing gone on the drum, if you can lift the drum with your fingers at the bottom of the drum in the door hatch even by putting lifting inside then the bearing has gone. the plastic is the drum.housing usually were the bearing housing is. if there is a lot of movement then the bearing has gone. usually the front bearing but you will need to remove the drum and separated the drum to remove the drum then the bearing, rust on clothing is the bearing as its the only part in the drum that is metal.
GE WBVH6240F... | Answered on Jun 27, 2017
Is the system filling up with water then halting with an E1 error or can you complete an entire cycle?
E1 in Samsung Front Loaders: It means the machine has detected an error in inlet water filter or the water pressure. Some of my sources indicate E1 could also be a leakage error It could all mean a faulty sensor but you should check th water lines, the door seals and the floor beneath the machine for tell-tale signs of a leaking system. Is the system filling up with water then halting with an E1 error or can you complete an entire cycle?
If you can fill the washer, but it faults with and E1, and can go no further, my research shows a common cause for the problem is the PVC tube connecting the pressure sensor to the drum has experienced a problem. In some modern washers, the water level is measured and regulated with a pressure sensor connected to the tub with a plastic tube. As the water level rises inside the drum, the pressure rises inside the sealed tube. The tube can sometimes become detached or even plugged with lint, soap or wash grime. Check the pressure sensor line to make sure it is attached to the drum and is completely unobstructed by foreign objects or deposits. If so, clean the debris and/or reattach the tube to the drum and try running starting a cycle. If you don't get the E1 code - Hooray, everyone has clean clothes again :-)
If this does not work, here is a link to a Washing Machine User Blog which might be able to offer more experts and more specific information http://www.applianceblog.com/mainforums/washers
Hope this answers your questions and helps FixYa! If you found my information useful and informative, won't you please show some love and rate this solution or better yet, send us a brief testimonial on how our free support made your day and averted disaster.
Thank you for choosing FixYa.com.
Colt Baldwin - FixYa.com Guru
GE WBVH6240F... | Answered on Mar 14, 2015
Try two things: Add several cups bleach to the tub and run it a complete cycle. When not in use, leave the door open so it will air out.
GE WBVH6240F... | Answered on Dec 07, 2014
GE WBVH6240F Front Load Washer Logo
350 questions posted
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
rubber burning smell
  • Washing Machines
