20 Most Recent
GE Spacemaker WSLP1100D Top Load Washer Questions & Answers
GE GSLS1100 Spacemaker won't spin
Solved: There was a piece of fabric caught in the water drain pump. Opened the cap at the back bottom right of the washer and pulled it out. Worked fine after that.
Washer won't drain!
Sounds as the pump has gone wrong, if it's turning & doing the usual cycle except for draining the motor is fine, check the pump filter trap to be sure there is no obstructions as a simple penny can stop the pump motor turning preventing the machine from draining, I hope this helps.
Washer constantly draining after first cycle
For the machine to keep filling it would indicate that there is a siphoning problem. Check the outlet hose is not running along the ground, it has to rise up then loop back down or the water will just run straight down the drain. If the problem only happens after the first pump out it would indicate the end of the outlet hose is lower than the drum or there is no air break around the outlet hose. (The
stand pipe should be larger in diameter than the hose from the machine).
http://selfix-uk.co.uk/under%20sink%20plumbing.html
Ge wslp1100a0ww washer leaves clothes soaking wet, not spinning properly
You don't say whether agitation is normal. Improper spin can be slipping V belt (stretched or cracked), part #WH01X10081, or loss of transmission fluid. Is there oil on the ground under the washer (shouldn't be)? Let's start here. Motor, belt, and transmission are at the bottom of the washer.
