20 Most Recent GE WCVH6260FWW Questions & Answers
0answers
GE door boot gasket material?
Best way to remedy your problem is to replace boot. The boot moves and stretches quite a bit. Patch would hold up
11/7/2017 4:11:09 PM • GE WCVH6260FWW • Answered on Nov 07, 2017
My GE washing machine (Model WCVH6260FWW) quit mid cycle. Digging in, I found the drain pump was warm and trying, but failing to operate. I removed the pump and performed a bench test. It failed to
Hello Sounds like you need a new pump assembly..P#WH23X10026 you can get one from AMAZON Good luck..
7/10/2017 2:31:14 PM • GE WCVH6260FWW • Answered on Jul 10, 2017
2answers
Our washer will not finish wash cycle It seems
Repair Manual Link If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
9/26/2016 12:02:52 AM • GE WCVH6260FWW • Answered on Sep 26, 2016
Washer door drops when i open it.when i close it i have to lift door. hinge seems loose
This may seem obvious, but tighten all the screws on the front panel, especially around the door hinge area. A #2 Phillips screwdriver is all you need. Also, try to see where it's dropping - is it at the door itself, or does the entire hinge assembly sag where it enters the washer?
6/26/2014 11:51:50 PM • GE WCVH6260FWW • Answered on Jun 26, 2014
Washer just locked then started a humming noise. Cannot get door open
Try unplugging the power cord for 12 seconds or so. That will often re-set electronics.
6/7/2014 9:33:01 PM • GE WCVH6260FWW • Answered on Jun 07, 2014
How do I pull up error codes
Follow these steps to enter the service mode on a GE front load washer. 1. Close the door. 2. Clear current cycles by pressing the power button. Make sure the screen is blank before attempting to enter the service mode. 3. Disconnect power to washer for at least 30 seconds. 4. Reconnect the power and within 30 seconds of reconnecting power complete the next step. 5. Press signal -delay start -signal - delay start. If you successfully enter the washer into the service mode, t01 will be displayed and the door will lock. Here's a link to the codes: http://www.appliance-repair-it.com/GE_front_load_washer.html Good luck with your troubleshooting!
6/1/2014 4:38:48 AM • GE WCVH6260FWW • Answered on Jun 01, 2014
0answers
Front load door will not shut due to the latch
The locking latch on your machine needs to be replaced and install new one If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
3/15/2014 9:29:26 AM • GE WCVH6260FWW • Answered on Mar 15, 2014
WCVH6260FWW drum sticking
you have an item in between the inner and outer drums if you take the heater unit out you should now be able to see it remove it
1/12/2014 2:26:51 PM • GE WCVH6260FWW • Answered on Jan 12, 2014
LOOSE DRUM
TIGHTEN DRUM
11/4/2013 12:25:49 PM • GE WCVH6260FWW • Answered on Nov 04, 2013
GE WCVH6260FWW Logo
123 questions posted
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
ge washer model wcvh6260fww fills
  • Washing Machines
