20 Most Recent
GE Energy Star 3.7 IEC Cu. Ft. Front Load Washer with Stainless Steel Basket Questions & Answers
Won't drain right
Check the pump. There is most likely something obstructing it. It is probably a coin or something like that. There should be 2 hoses that attach to pump. One that the water comes into and one that the waterwill discharge. It will be one the the water discharges from. Make sure that you get a pan or bowl so when you disconnect the hose the water will go in this instead of on the floor.
My unit won't spin. I
(try this!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor. ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
Ripped tub seal< can i
you can do it its very hard ...well it makes your fingers work very hard :))))))))))) just make sure you locate new seal on right and put clamps back on ... then give it a tug all the way round when on ... u dont wont to flood your kitchen :))) bsc appliances 07779933829 uk
Knocking noice during spin cycle
I don't know your particular machine but the initial cure is the same on all, front or top loaders.
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine (sorry about my UK spelling!) and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
John C
Would drain and checked the drain, not much in
This is an indication that there is a communication error between the Central Control Unit and the EEPROM onboard the CCU. F01 can also be displayed if the onboard "Pump Driver" fails to engage. Generally in order to correct this failure will require replacing the CCU. There is no way to test and verify if the control board has failed.
My GE washer wbvh5300kww beeps at me when I hit start
I am also having this problem as well. Trying to seek (once again) a solution as having to plug/unplug the washer before each use is really annoying.
Can anyone tell me how to run the test mode for this washer? I don't see that detail anywhere in my manual. Thanks.
