20 Most Recent
Sanyo PLV-Z4 Multimedia Projectors Questions & Answers
Replace lamp warning light goes on after raplacing it with the new lamp
I had the same problem. There is an internal reset button just above the lamp that needs to be reset. You have to take the cover off, which would void your warrantee, but it's quite easy. My lamp only had 660 hrs, and I bought a new one too. So now I have an extra. My guess is that my filter was getting clogged causing an overheating situation and tripping this reset button which I'm guessing is a heat sensor.
Sanyo PLC - Z5 Lamp Replacement Light
Just had the same problem. Based on other suggestions on here I tried resetting the overheat switch, and IT WORKED!
So, you have to pull the 6 screws (one of them is shorter than the rest, remember where it goes) that hold the top on the projector. 3 are on the back, 3 on the bottom - look for the arrows next to the screws.
Put the projector on it's feet, and pull off the top. The button wires will still be connected, so just hold onto the top and find the black circle/shaft above where the lamp is. The shaft has white paint on the top/tip of it. Push it down with a light amount of force. You should hear/feel it click.
Put top back on, put screws in, and you should be good to go.
Don't forget to reset the lamp replacement counter in the menus.
How to change lamp timer on sanyo plvz4
Hello* Turn the projector ON, and press the MENU button to display the on-screen Menu. Select the 'setting' menu with point UP/DN button. Press '>' button to acess sub menu items.* Select the Lamp Counter reset and press the OK or '>' button. "Lamp replacement counter reset?" will appear. Select "Yes" and then press OK or ">" button8 Another confirmation dialogue box appears, and select "Yes" to reset lamp replacement counte.** Do not reset the lamp replacement counter without implementing lamp replacement. Be sure to reset the lamp replacement counter only after replacing the lamp.
I have a sanyo PLC-XE40
There is a lens/lamp filter which must be taken out and cleaned, use good air jet to blow and brush out dirt. If the filter is clogged then the lamp might heat up and so shut down..
if the fault does not clean try and force cool the unit, if not there is fault in the power supply, possible lamp problem or circuit error on load or heat.
You will need to open and use a test bench to check out the sections, one by one, use of multimeter and good equipments may be needed . If not take help with consensus.
I have a PLV Z4
the wires are shorting out in the power cord, replace it asap!
