20 Most Recent Kenmore 46462 Front Load Washer Questions & Answers
Check the pump first but you most in likley have a bad circut board. On the front of the washer their is a kick panel. Remove the 3 screws on the bottom and remove it. Taped on the inside is a book of codes and some self diagnostics you can run. This is all your repairman will do and he will order the circut board and charge you more than the washer is worth.
Kenmore 46462... | Answered on Aug 20, 2018
yea these things are a mother to get level. And if you get them right, a wood floor will settle under there heavy wieght. I found that after the third releveling . The last time i set all the screw adjusting feet to 35 inch pounds after initial truing. It has been good now for 18 months. One more thing, they have cast ceramic "frames" around the nylon drum that wont take too much abuse. Be sure its level before you cause serious damage.
Kenmore 46462... | Answered on Dec 30, 2017
Make sure the washer is level. Yoou may need to replace the belt. they go out in a few years
Kenmore 46462... | Answered on Oct 06, 2017
Hello SMCCRAVE,
You are referring to a top loader problem.
A front loader is different the following is from the youtube page that has video explaining the possible issues!
Washing machine not spinning? This video provides information on how to troubleshoot a front-load washer that won't spin and the most likely defective parts associated with this problem. These are sorted from most likely to least likely to be the issue.
Commonly replaced washer parts:
Drive belt
Door lock switch
Motor control board
Stator/rotor
Drive motor
Good Luck!
Rich Lilja
Kenmore 46462... | Answered on May 22, 2017
This solution is the best! Thank you so much. You just saved us a whole bunch of $$$ and frustration. 1 baby sock and 1 pair of undies later - the machine is back to normal. THANK YOU!
unplug from power source...remove front lower panel (3 sheet metal screw wirh 1/4" drive head located on the lower lop of the panel)...open pump strainer (looks like a large stove knob, Turn it counter clokwise, lookout! lots of water will gush out... back flush the pump by filling the outet of the drain hose ( this may dislodge debris that may jam your pump)...re-assemble, plug to power, and turn-on. In my case, there was a piece of a pencil lodge in the pump impeller. I had to disassemble the pump. it can be done if you are patient and able to figure out how the plastic thing come apart. Good luck! If all else call the pros!
Kenmore 46462... | Answered on Apr 01, 2015
Generally speaking you will need to at least remove the top of the machine,usually there are a few screws and then it pops off.Also see if the control panel has a screw in it that attaches to the top of the machine.If so you will need to remove this also to avoid breaking the panel. Hopefully you will be able to view all you need to , do you see any signs of the drum hanging awkward like for instance it seems to pitch back,if so there is the issue.I have had to reattach the suspension spring that balances the drum.If so get a good pair of locking pliers to stretch that spring back to its original location,this could have come off during transportation.Hope this helps.
Kenmore 46462... | Answered on Apr 30, 2014
F03 error code means that there is either fill problem, a drain problem or a water level pressure switch failure .
First ensure the machine is filling.
When the drain system is causing the F03 error do the following.
Ensure that the drain hose is not kinked or clogged.
If the drain hose is OK check the drain pump.
Start unplugging washer from main and remove the service panel at the bottom.
Follow the instructions on manual to remove panel.
Access the water pump and remove the hoses, clear any blockage in there.
Use a container to collect the water, be prepared. If machine has lot of water inside, remove some water with a sponge before undoing the pump.
Kenmore 46462... | Answered on Jan 15, 2014
that is called an eco ball it is part off the machine
its job is to save money by not heating the water below it in the drain pipe
Kenmore 46462... | Answered on Dec 29, 2013
I dont see why there would be a magnet in the dispenser draw in the first place,,,, is it possible it somehow got in there by accident and when it fell out you thought it belonged in there ?
Kenmore 46462... | Answered on Dec 16, 2013
Kenmore 46462 Front Load Washer Logo
361 questions posted
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
View Most Popular
  • Kenmore Washing Machines
Most Popular Question
kenmore washer stopped f21 error code
  • Washing Machines
