20 Most Recent Kenmore Oasis HE 27062 Top Load Washer Questions & Answers
contact the manufactures website and download the user manual and compare the section on trouble shooting for a possible answerer there could be a fault on the control panel if necessary contact the local engineer for the advice you may need as from a distance we cant see the problem at first hand eric
Kenmore Oasis HE... | Answered on Dec 29, 2017
sounds weird but I would check the water inlet valve
Kenmore Oasis HE... | Answered on Feb 20, 2015
Check the basket the very bottom ring is the float and some how leak and do not float well enough to disengage the basket when agitating and strips the hub.
Kenmore Oasis HE... | Answered on Feb 09, 2015
I jhavent got to figure out what an F1 is. I suspect its a "Fill" code 1?
Does it fill with water okay? If it dosnt fill within a cretian time I bet the computer see this and causes a F1? But Im guessing.
If it is this take your hoses off the washer not the faucet. put loose ends in the washer tub and hold em down while Turning on the water. Look for rust, sand or any thing that might be coming into the screens. If you have low water pressure this could be the cause also. But only remove the hose on the faucet end if you have low water pressure then look for the screens on the faucet end.
Also check the inlet of the washer at the water valve for mud, dirt or anything.
I need to know if this is what an F1 code is if you wouldn't mind posting back and if this helps you please rate me as high as you can. Thank you and good luck.
Kenmore Oasis HE... | Answered on Nov 10, 2011
Bravos is the same as Oasis and Cabrio brands Click here for possible solutions.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Kenmore Oasis HE... | Answered on May 18, 2011
Call your Sears customer service representative and not repair people. Our repair representative for Sears in Houston flately denied there was a problem. I called the right people and took care of that. Make sure you give them the model and it manufacturing ID number. No matter what they tell you it is a defective board made by Whirlpool who also made your machine. It is covered under a warranty( recall) . If you Google oasis kenmore problems your computer will light up. It took me a while, but they fixed mine. Two weeks later it was another problem. I spent 1200 new in 2007. We have hade no less than 6 service calls. My old washing machine is being used by my inlaws and is 15 years old. The way sears has handled this they have done a great deal of damage to thier loyal customers.
Kenmore Oasis HE... | Answered on May 06, 2011
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after
all other causes listed have been ruled out.
Kenmore Oasis HE... | Answered on Feb 03, 2011
F-1 Error Solution
Kenmore Oasis HE... | Answered on Jan 24, 2011
Hello there: if you have disconnected the line tothe drain pump and it appears to be clear check all hoses first and if they are clear then yes i would have to say thatthe pump may be bad But to make sure remove the pump and i you can dissasemble the pump and inspect the internal parts a lot of time you will find lots of things inside of the pump that you cant see Also check the impellers inside of the pump that are used to pump the water out of the machiine these parts are known to wear out over time ok so please check the pump out ok Best regards Mike
Kenmore Oasis HE... | Answered on Jan 09, 2011
Check all of your hoses and see if it is wet. Don't neglect to check the water supply hoses for your hot and cold water. 9 out of 10 the leak is directly under the washer so if you can tip it on it's side you will a good view of the underneath carriage. Good Luck
Kenmore Oasis HE... | Answered on Jan 07, 2011
The LD error code on these machines is like having a business consultant come out and look at your company. What he or she will tell you is technically correct and absolutely useless as far as fixing the problem.
The error normally occurs when you have an obstruction in the drain line. It sounds like you have checked this out, but I would recommend you remove and clear the drain pump and you might as well do the same for the recirculating pump at the same time. Put things back together and see if this does not solve the problem.
If it does not you could try replacing the drain pump, but it is an expensive part and you will not be certain this will solve the problem, as the problem could be in the wiring or the main control board.
There is also a recall on these machines. To see if your machine qualifies, Call 1-800-659-7026
Kenmore Oasis HE... | Answered on Jan 06, 2011
Kenmore Oasis HE 27062 Top Load Washer Logo
Popular Tags
113 questions posted
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
View Most Popular
  • Kenmore Washing Machines
Most Popular Question
kenmore oasis washer 110 27062602 sd
  • Washing Machines
