20 Most Recent Kenmore 3.2 cu. ft. Plus Top Load Washer Questions & Answers
Pry the top lid off the agitator.
Remove the plastic shield inside.
Use a 7/16 socket and extension to remove the bolt.
Pull the agitator off the shaft.
Kenmore 3.2 cu.... | Answered on May 29, 2019
If you have moved it recently there were some Kenmore washers that had pins on the tub underneath that fit into sort of cups. I leaned mine over and didn't get them back into place and it shook like a earthquake . There are some machines with bumpers underneath that keep the tub from moving too far to the sides. See if you can move the tub by hand side to side on all four directions to check movement. Go online and check your model for recalls, consumer complaints, world of wealth on the net.
Kenmore 3.2 cu.... | Answered on Nov 27, 2017
Maybe lid switch is bad. I think that model has a fuse in the switch assembly if I remember correctly.
Kenmore 3.2 cu.... | Answered on Sep 28, 2017
you'll need to access the pump and remove the hoses. Clean the inlet screen.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Kenmore 3.2 cu.... | Answered on Feb 02, 2016
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps.
Gene
Kenmore 3.2 cu.... | Answered on Dec 03, 2015
Its very possible it could be one of the tubes that run to the fabric softener or detergent.
Kenmore 3.2 cu.... | Answered on Nov 08, 2015
It sounds like it could be the coupling that has worn or broke, to verify this put the washer in spin, let it drain the water out (if it will) then turn off the timer or open the lid, wait 10 seconds or so then start back up in spin. If the washer just whines then it is most likely the coupling. I have put together some instructions on this if you follow this link it will tell you more about it and how to replace it if you wish. Let me know if this helps.
http://www.fixya.com/support/r4670549-drive_coupling_replacment
Kenmore 3.2 cu.... | Answered on Sep 28, 2015
replace the motor coupling.
Kenmore 3.2 cu.... | Answered on Jul 17, 2015
I bought mine brand new December 2005. Kenmore washer.
Kenmore 3.2 cu.... | Answered on Mar 04, 2015
What series is this washer?
I’m happy to help further over the phone at https://www.6ya.com/expert/tami_f8d2d553d5094045
Kenmore 3.2 cu.... | Answered on Mar 03, 2015
Good for you. I don't think this model has a belt, I believe it is a direct drive with a coupler. Most likely, if you can hear the motor, the coupler has done it's job and sheared. The coupler is 20 bucks and my wife and I just changed ours out. I need the entire model number and I will get you the part schematic and we will get you going.
Kenmore 3.2 cu.... | Answered on Feb 26, 2015
It could be a timer, motor or wiring problem. You would need to check for 110 volts at the timer or motor when in the higher spin mode. If you are getting 110v you have a bad motor. No or low volts you have a bad timer. The motor is either a 2 or 3 speed motor and you would have to determine which winding to check for the 110v. The schematic is usually glued to the inside rear cabinet. Please rate this post.
Kenmore 3.2 cu.... | Answered on Nov 09, 2014
This may or may not help.
http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0305295.pdf
Kenmore 3.2 cu.... | Answered on Oct 29, 2014
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
582 questions posted
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
View Most Popular
  • Kenmore Washing Machines
Most Popular Question
want know stack kenmore elit gas dryer
  • Washing Machines
