20 Most Recent
Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer Questions & Answers
Freezer compressor not able to start and noisy.
It sounds like the compressor is locked (seized). The current overload is doing it's job by opening the circuit. Take a current reading, on the common leg, while the compressor is trying to start. The locked rotor amps (LRA) for that compressor will be indicated on the compressor tag. If it's drawing LRA while trying to start, you need a new compressor. Which is the costliest part in that unit and requires specialty tools to replace.
Sears Coldspot 17 frostless freezer not defrosting
One reason for the fan running is that it is trying to distribute the air in the compartment. Look at the very rear of the freezer on the bottom and see if the little vents, which allow water to disperse, are not filled with frozen ice. If so, turn off the fridge (unplug it) and use a hair dryer to melt that ice until it is all gone. That will probably fill the condensation pan under the unit and you'll need to empty it.
Kenmore Upright Freezer Alarm
I think problem its not with thetmostat but the compresor work but not correctly not have enought power to create pressure.
Why wont my freezer wont freeze everything else does
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
Air needs to circulate in both parts (dependent on eachother)
970 224222
check and empty the drain pan, you should be able to gain access by removing the vent grill below the door if there is one. The pan is under the unit somewhere. There is also a drain tube, make sure its not blocked with ice.
Ice cream not freezing hard
Ice cream needs to be at 10 degrees or colder to stay hard. Check your thermostat and move it colder if you need but give it 24 hours to stabilize to the new setting. Another thing you might check are the coils on the outside of your freezer. They will be on the back or underneath your freezer. What you need to look for is to see if there is any lint or dirt that might be built up on the coils. If they are real dirty they need to be cleaned off with a vacuum or an air hose if you have one. The dirt build up keeps the freezer from cooling efficiently and causes it to run warmer than normal. If all of that is clean and boosting the thermostat to a colder setting does not take care of it you might need to call a service tech. Hope this helps.
