Get online and got to www.google.com In the google search box type: "ASUS Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals and search them for System Recovery or Factory Restore.
System Restore will allow you to select a Restore Point (date and time) to set your system back to when it was working ok. It does not delete any of your data, documents, music, pictures, videos or programs (unless the program was installed after the Restore Date you selected). System Recovery (sometimes referred to as Factory Restore) will set your system back to when you first purchased it. It Deletes Everything. Most times the System Recovery does not work unless there is a recovery partition on your hard drive created by the manufacturer. If you are trying to recover from a set of cd's most times it does not work. Instead of doing a System Recovery it's much easier to just Reinstall Windows. Look on your computer for the Certificate of Authentication (COA) Sticker. It will tell you what operating system is on your computer and it will give you the Product Key Code (a series of 5 letters and numbers) that you will need to activate windows. If you don't have an operating system disk, borrow one from a neighbor, friend, relative or co-worker. Just make sure it is the same as your COA Sticker's operating system or it will never activate. Also make sure you get the COA Product Key Code for the disk you borrow because sometimes the system will ask for the one that is on your system and sometimes it will ask for the one from the installation disk.
105 questions posted
1,757 Questions
347 Questions
315 Questions
269 Questions
198 Questions
