20 Most Recent
Cobra 150 GTL DX Base CB Radio Questions & Answers
Cobra 150 gtl dx peak and tune
first off if you don't have the proper equipment to do this you will have a cobra 150gtl dx used in the box that you can use for a chock block. turn the wrong can and you will never be able to get it back to working order.
Cobra 150 gtl keys up
First thing I would do is check the SWR on the antenna. These newer radios have a strapping diode that shuts them down when the reflected power heats the finals up to keep from blowing them. Once they cool off they will work again.
I jus was wondering, can the cb radio and the
CB radios and hand-held CB radios can operate on the same channel and be in contact with each other. Other hand-held radios do not operate on the same frequencies and even though they may have channel numbers the channels have different frequencies and will not operate to CB radios.
What linier do I use with a cobra 150 gtl?
None ,they are illegal . you could put just about anything you want to pay for. Just remember ,the man might get you and you loose all your equip. and get a hefty fine.
Transmitting fine, not receiving an single thing..
the problem could still be with your swr . If your jeep is fiberglass at the point where your antenna connects that could be the problem. move it to a point where there is metal to get a good ground plane and you should hear people talking.
COBRA 150 WILL NOT TRANSMENT
forgetting to turn it on. making sure its in CB not PA mode.turn squelch all the way to left and rf gain to the right
