20 Most Recent GE 30 in.Profile JGP945 Gas Cooktop Questions & Answers
0answers
Need to remove the top of a JGP945BEK2BB to
after using the simmer portion a mini explosion occurs after about 10 minutes and the flame goes out. if other burners are on they also go out. only happens when simmer is on
3/13/2011 1:34:14 PM • GE 30 in.Profile... • Answered on Mar 13, 2011
Convert natural gas to propane
Hi, W/D here.
I can tell you how I have done a similar appliance. I contacted my local propane company. They had all of the orifices, and cross reference guides necessary to convert it over to propane and they did it for free. Contact your local company. If your's won't do it for free like mine, they can surely get you the parts reasonably, and provide further guidance.
Best regards, --W/D--
Please take a moment to rate this solution so that we may continue to improve in helping others. Thanks.
2/24/2011 2:14:49 PM • GE 30 in.Profile... • Answered on Feb 24, 2011
When I try to use
The electrical wiring under the burners has been short
probably from liquids leaks during cooking.
That is why you had the spark. The only electrical part you
have to your coo top is the electric ignite nothing else. So you should remove
all burners' assemblies from the top so to reach the bottom part where the gas
pipes are located and the ignite part no 318 in drawing Spark module
Part Number:
AP3778816made by GE.
So first you can use a hairdryer do try it out and be sure there is not and liquid in it and putelectrical plug again to test it. If you still have the same problem, replacethe Spark module with a new one.
Here below you will find theparts layout of your range for all the help you might need.http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5235927&diagram_id=25698825#d25698825
12/19/2010 10:45:24 AM • GE 30 in.Profile... • Answered on Dec 19, 2010
How to diagnose, remove and replace spark module
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
8/19/2010 12:34:13 AM • GE 30 in.Profile... • Answered on Aug 19, 2010
How can I open up
Hi
Please check the following link to know the instructions as to your requirements regarding to the repalcement of the top cover of cooktop...
http://www.ronhazelton.com/archives/projects/remove-install-cooktop.shtm
Let us know if you want somethin more else accept the suggestion.
Thankyou for contacting fixya.com
4/6/2010 10:15:36 AM • GE 30 in.Profile... • Answered on Apr 06, 2010
Clicking cooktop
Ours clicks when the igniters are trying to fire up the burners. Is something stuck? They start as soon as you turn the knob on and the next stop turns them off. Double check each knob to make sure you don't have a bad one.
Carl
11/26/2009 10:56:25 PM • GE 30 in.Profile... • Answered on Nov 26, 2009
Ignitors keep making ticking sound, all burners
Probably a spillage or boil over has clogged the burner and some of the liquid has dampened the shank switch mounted on the burner post. Get a shop vac and clean the burner. Wait a day or 2 and see if the switch stops. OR disable the ticky ticky by removing the bottom drawer and looking for the spark module. Remove one of the hot wires and tape it up. Light the burners like granny does with a match. LOL If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
7/17/2009 8:48:22 PM • GE 30 in.Profile... • Answered on Jul 17, 2009
One of four dials doesn't spark ignitors...
its a spark switch gone bad, 1 switch will turn on all four burner electrodes(its just easier 1 module)sometimes model dependant you can eplace justone switch, sometimes they come as a complete set
2/25/2008 2:45:41 AM • GE 30 in.Profile... • Answered on Feb 25, 2008
Replacing Grill module with gas burner on GE Gas cooktop (PGP990)
You can't modify gas appliances.
9/27/2023 5:42:09 PM • GE Cooktops • Answered on Sep 27, 2023
Wiring for GE Cooktop 1960s
I have an early 1970s GE, and we keep saying when it breaks down, we will replace it, but apart from replacing elements, it just goes on and on. Unfortunately, neither of your numbers give results. There should be a plate near the power lead that has the details and some have a parts manual and wiring diagram in the rear of the console if it has one. https://www.google.com/search?q=GE+82212+cooktop https://www.google.com/search?q=GE+YT123887L+cooktop ..
9/17/2023 10:38:35 PM • GE Cooktops • Answered on Sep 17, 2023
2answers
Fuse location on GE Profile PP975S Cooktop (If there is one)?
Question edited for clarity. There is no fuse, the loads are too great. The Service Manual is in the link. Check the Control Lock on Page 11. https://ja.safe-manuals.com/source/pdf/adea1af72b5b020af66562d603ff2631 https://www.google.com/search?q=ge+pp975s+fuse+location ....
12/25/2022 7:57:23 AM • GE Cooktops • Answered on Dec 25, 2022
How do you remove only the maintop cover of a GE JGP963 gas cooktop? I need to replace a part, but can't remove the maintop even after unscrewing and removing every burner.
It is a gas appliance. From the installation manual. Installation and service must be performed by a qualified installer, service agency or the gas supplier. It needs to come out as there is almost certainly fixings from below. Screws on the burners, only hold the burner rings down. The installation manual doesn't say how the top comes off, just how to install. No Service Manual for it. https://www.manualslib.com/manual/57348/Ge-Jgp630.html?page=1#manual ..
12/1/2022 8:15:10 PM • GE Cooktops • Answered on Dec 01, 2022
F152 error GE Monogram electric cooktop
Take out the right front burner and use your multimeter to check it for continuity. Only then can you be sure that the error code isn't lying to you. It is my guess, that with an error message so specific, that if no burners are working, it is not the front right burner at all. Hands on testing is the only way to be sure. F152 means the right front burner has failed, the sensor in it is bad, the burner will need to be replaced.
error code F152 ' Appliance Video
The element is $225.00 so it is not something to change on a guess. Full testing procedure here, or call for a Service Engineer. https://www.appliancepartspros.com/answers-for-ge-element-radiant-lt-wb30t10080-ap3188020-question-148609.html ..
3/20/2022 6:27:28 PM • GE Cooktops • Answered on Mar 20, 2022
Where can I get replacement control knobs for my GE JGP636 gas Cooktop
do an online search or if a repair shop in area order from them
1/22/2022 1:33:42 PM • GE Cooktops • Answered on Jan 22, 2022
2answers
Lamona ceramic hob
Ceramic cooktops need the correct type of pots or they leave marks,check your instruction manual.
2/17/2021 6:49:19 PM • GE Cooktops • Answered on Feb 17, 2021
KNOBS WON'T TURN
if the knobs wont turn, the cooker needs to be serviced by a gas engineer the gas taps are seized they need gas tab grease
11/1/2020 7:28:10 PM • GE Cooktops • Answered on Nov 01, 2020
GE 30 in.Profile JGP945 Gas Cooktop Logo
17 questions posted
Top GE Cooktops Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
View Most Popular
GE Cooktops
  • GE Cooktops
Most Popular Question
when try use
  • Cooktops
