20 Most Recent
KitchenAid 30 in. KECC506R Electric Cooktop Questions & Answers
Broken knob
Turn off the power to the appliance. Squirt WD40 liberally all round the knob, trying to get it in behind it. Wiggle the knob and press it down and up if possible to let the WD40 oil work in to the dirty or stuck joints. Leave for a few hours and wiggle it again to see if its loosened up.
Flashing lights wont stop
Possible this is an error due to a protection and so it cannot switch on the cooker/oven. remove power off and check the coils, check for leak to the body of the oven , if so it can trip on protection.Also check the sensors- thermistor sensors. Check for insulation failure and insects that are trapped.finally check the control panel for moisture and if so dry the panel and reconnect the connectors once again.
The little circle in the middle went on suddently
To lock and unlock the cooktop follow the following instructions:
To Lock Cooktop: Touch and hold the CONTROL LOCK/
ALL OFF keypad for 5 seconds. After 5 seconds, CONTROL
LOCK will glow red, indicating that the cooktop touch controls
are in the lockout position.
To Unlock Cooktop: Touch and hold the CONTROL LOCK/
Apparently a pizza stone was set on glasstop
Hi there.
It depends on the depth of the scratches. For minor scratches I normally use a cheap toothpaste and a fine soft cloth. Polish compound and a polish machine can be used on deeper scratches.
Iceman.
I was cooking popcorn on my glass cooktop and the
You may have melted the bottom of the pan you were using into the glass. Copper bottom and alum pans sholdnot be used at high temps on a glass top. (never use porclin or glass pots)High temps can etch(mark or discolor) the glass.
Coil element on kitchen aid model ker1201 slow to
some of the coiled eyes have two coils(elements). one of the coils can burn into at any point around the element rendering it useless while the other can still work. when you lift the glass top you will see the elements are shaped like springs. the elements metal is very britlle.it is you have to replace the entire eye to fix it. the coil most likely had a very gap in the break and acted like a short making and breaking connection until the gap was too wide then nothing. easy fix. just replace the entire eye (power UNPLUGGED!!!) match the old wires with the new part as you take the old part off. I mark them even with a sharpie. it has 3 to 5 wires on that plug into the eye unit. estimated cost for the part online is about 40 to 65 bucks.
HOT SURFACE LIGHTS
Hold the button down 5-6 seconds and it will go off...then to cut on...press down again for 5-6 seconds and it will come back on.
