20 Most Recent
HP Pavillion ZV6000 Notebook Questions & Answers
HOW DO I ADJUST PAVILLION G6 VOLUME CONTROL
so can't go to HP.com and just RTM then post here to Zv6000
and for sure is not that PC, wow why do that?
NO OS told at windows what>? or ??? there are others.
USA pc?
G6 is not a PC it is base series and guess what they are not all the same at all. for sure OS there. and sound options many.
G6-dash what is the dash number NOT TOLD and wow answers hard.
there are 3 ways (AT LEAST) RTM YET?
the sound bar KEYPAD , or control panel SOUND, the speaker icon in tray
G6-xyz123 , not told full model
we can not guess, full model names ever and there are 4 decades of models.
HERE IS A PARTIAL LIST NOT WORLD WIDE
https://www.notebookcheck.net/HP-Pavilion-g6-Series.55423.0.html
IF ALL WAYS FAIL THE MEANS THE SOUND DRIVER ARE MISSING OR DEAD WRONG.
NO OS TOLD BUT IF UPGRADED THE OS ,LACKING HP.COM SUPPORT THEN SURE ALL THAT IS DEAD, SURE.
Rs 480m-test bios message on
First off, Norton is messing with the operating system and toss it out. Once it is gone, things may go back to normal, that is if it has not totally been corrupted.
White screen start up
You LCD display panel or display cable needs replacement if it progressively turns white when you boot up.
Hp g60-235dx notebook screen flickers
This can be caused by a few things. One the heat computer gets hot and flickers. Suggestion: Clean laptop of dust and debree at the internal level. This can be caused also by a video card which got hot and cracked the solder weld on the internal chip. This is a problem for most laptops when they get hot. There is several places that redo the boards for a fair price. There really is nothing you can do about that accept to replace the board or have it soldered over again to seal up any cracks. The way to tell is hold the PC with both hands and slightly bend it back and forth and see if it shorts out clears up or blinks. Third this could be also caused by the video cable came loose of if it was dropped it may have jarred the cable plug. The way to tell if that is the case is taking it apart and cleaning the cable input plug with dissolving alcohol and a q-tip wait until dry and re plug it in. One of the capacitors could be damage or bloated and needs to be replaced. You can also replace the screen as well. So as you can see there are several possible causes for this issue. I would recommend taking it in to a good shop and have them diagnose what is going on with the video or screen. Messing with it without experience can lead to serious damages if you do not know what your doing. Thanks for asking John
