20 Most Recent Kenwood KDC-MP232 CD Player Questions & Answers
0answers
Kenwood KDC-MP232
This is a similar repair, but the resistors you need to reflow solder on ae on the bottom of the circuit board, not the top like the other models. The reference numbers for the resistors are R130, R131, R133, R135, R136, R137, R138, R139, R140, AND R141.
They are 4.7 ohm resistors and should have "4R7" printed on the top of them. They are not as close together as the other model has them, but if you take the board out of the unit you should be able to find them. Put just a touch of solder on both sides of each resistor. This should be plenty to fix this problem.
It is also possible that you may have another cause for this problem, but this is the most likely cause.
I hope this is some help for you. Let me know if you need further instructions.
Dave
6/11/2017 1:56:16 PM • Kenwood... • Answered on Jun 11, 2017
What does ANT Cont mean
This means Antenna Connector.
7/7/2014 3:11:19 AM • Kenwood... • Answered on Jul 07, 2014
What Color Is The Power Wire
Red ignition + yellow is constant 12v+
7/7/2014 2:48:49 AM • Kenwood... • Answered on Jul 07, 2014
How to set clock on microwave
http://www.masterspas.com/documents/manuals_av/Kenwood_KDCMP232_Manual.pdf Download the user manual to this set by this link. It has all details Electro help
6/22/2014 7:11:23 AM • Kenwood... • Answered on Jun 22, 2014
0answers
0answers
I need to know which pin is for what
hi...try and check this site, there are lots of pdf about Kenwood KDC-MP232 CD Player...http://search.4shared.com/q/50/kenwood
9/24/2011 1:55:27 PM • Kenwood... • Answered on Sep 24, 2011
2answers
I Put two new speakers
Protect means the speakers are drawing too much current. Recheck your installation to make sure the wires are not shorting to each other or to the chassis. If the wires look good, check the impedance of the speakers using an ohmmeter. Anything less than 4 ohms is probably a bad speaker, but compare your readings to the spec on the box. Please let me know if you have more questions, and thanks for using FixYa.
4/29/2011 8:35:23 PM • Kenwood... • Answered on Apr 29, 2011
Colors of wires for which speakers front or rear
LF+ white
LF- white/black
RF+ gray
RF- gray/black
RR+ purple
RR- purple/black
LR+ green
LR- green/black
2/19/2011 4:25:54 PM • Kenwood... • Answered on Feb 19, 2011
0answers
How do I enable the Auxillary option on my
when your car is on, turn the stereo off. you should be able to access a menu somehow when the stereo is off. in that menu, you should have the option to toggle the aux source on or off. simply switch it to on, then turn the sterreo back on, and hit the source button. it should now be ready to go.
2/13/2011 11:25:15 PM • Kenwood... • Answered on Feb 13, 2011
I have a kenwood that says it is sirus ready what
has a plug for a sirus tuner, the tuner sells at your local audio shop. units are not cheep.
2/9/2011 10:35:24 PM • Kenwood... • Answered on Feb 09, 2011
My kenwood cd player is
the output ic inside of the deck is probably bad. unless you are good a desoldering and soldering it will need to be repaired by a professional.
1/18/2011 6:15:23 PM • Kenwood... • Answered on Jan 18, 2011
What year is a KDC-mp232
2005
1/17/2011 7:02:53 PM • Kenwood... • Answered on Jan 17, 2011
Kenwood KDC-MP232 CD Player Logo
74 questions posted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
colors wires speakers front or rear
  • Car Audio & Video
