20 Most Recent Kenwood 2005 KDC-MP5028 CD/MP3 ReceiverFree Standard Shipping Questions & Answers
BLAUPUNKT radio mute and volume haywire
yea the got a short somewhere. Horn fuse might or might not work something with the radio. I would say start with the horn. The horn is a controlled short sometimes shorts it self out. Open your steering wheel and work from there. For your radio look at all the fuses that you know work the radio and go from there. What kinda car is it year things like that would help because if it older wires, fuses, fusible links things like that go bad over the years. Especially if you run a lot of power through the wires that was made for that kinda power like upgraded speakers, headunit (radio) amps things like that. Older cars and trucks are make with cheap radio wires. hope this helps
5/19/2014 12:02:02 PM • Kenwood 2005... • Answered on May 19, 2014
0answers
0answers
2005 KDC-MP5028 CD/MP3 ReceiverFree Standard Shipping: need to unlock a kenwood stereo that has the navig...
need unlock code bought used car battery died stero needs code dealer has no idea
8/28/2010 3:54:10 PM • Kenwood 2005... • Answered on Aug 28, 2010
No lock code for car stereo
Here you go buddy:
http://www.fixya.com/support/r538828-security_unlock_code_kenwood_most_models
11/23/2009 1:50:40 AM • Kenwood 2005... • Answered on Nov 23, 2009
I have a mp5028 and it tells me 2 enter the code.
you will need a remote for this
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
7/15/2009 5:50:05 PM • Kenwood 2005... • Answered on Jul 15, 2009
Unlock code for kenwood model kdc mp5028
Hey there joe,
Click here, it will bring to a Tip page authored by one of our best technicians (Robotek). He outlines the procedure for clearing the code on most Kenwood models.
If this gets you going, don't forget to give Robotek a rating Remember: Good things come to those who Rate!!
Mike
4/20/2009 10:49:03 PM • Kenwood 2005... • Answered on Apr 20, 2009
2answers
Kenwood Tuner Frequency Steps Problem
MichaelBlackDo you know where I can find the remote key combination to do the same with KDC-MP538U? (To transform it to the European system)
Thanks in advance!
1/15/2009 12:15:13 AM • Kenwood 2005... • Answered on Jan 15, 2009
How to set europe freq on KENWOOD KDC-BT838U car radio
Last night i got the answer from KENWOOD Support
Press and hold in the SRC button until the unit turns off. While power is OFF,
press and hold FNC and AUTO/TI buttons, and momentarily press the SRC button to
power the unit back on. Continue to hold the other buttons until the unit comes
back on completely.
I did it and it works
Enjoy
1/14/2009 5:09:28 PM • Kenwood 2005... • Answered on Jan 14, 2009
0answers
Kenwood KDC-MP5028
with the unit in standby, press the menu key, use the joystick control to choose aux, and set the aux option to "on"...then press menu again to save...when you next switch on the unit, using the SRC button you can cycle through the available options...cd - tuner - aux..etc etc
7/28/2008 2:19:29 AM • Kenwood 2005... • Answered on Jul 28, 2008
My car stereo
on your radio there should be 2 sets of outputs high and low you probably have set to low just switch to high and run your speaker wires accordingly to amp
5/7/2008 6:25:51 PM • Kenwood 2005... • Answered on May 07, 2008
Need the wiring schematics
5/7/2008 6:20:28 PM • Kenwood 2005... • Answered on May 07, 2008
Not sure but
yes its called a multi cd changer
5/7/2008 6:15:25 PM • Kenwood 2005... • Answered on May 07, 2008
Radio Removal
hi cant find reoval for this odel, but am 90% sure that : http://manuals.kenwood.novenaweb.info/languages/EN/support/manuals/KDC-MP6090R.pdf
is the same to remove see page 42
Regards
Mark
Blue ICE
3/22/2008 11:38:59 AM • Kenwood 2005... • Answered on Mar 22, 2008
Is it Dead?
hi it sounds like the cd mech is wurring so power should be ok.
try RESETTING the unit with the reset button, you will need a pen tor a pin to do this in most cases. if still no joy, then double check that you are getthing two pwer feeds to the radio
1 should always be there this is the perminant power feed. and the other4 should only be there when the ignition is on.
let me know how you get on.
Mark
Blue ICE
www.blueice-electronics.co.uk
2/26/2008 11:13:27 AM • Kenwood 2005... • Answered on Feb 26, 2008
Forgot my code.
try this
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
1/12/2008 4:03:06 AM • Kenwood 2005... • Answered on Jan 12, 2008
Kdc-w4534
" protect " is flasing on my w534 cd player and my cd player will not work any more . any ideas
12/25/2007 7:45:10 PM • Kenwood 2005... • Answered on Dec 25, 2007
Kenwood 2005 KDC-MP5028 CD/MP3 ReceiverFree Standard Shipping Logo
21 questions posted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
blaupunkt radio mute volume haywire
  • Car Audio & Video
